under radiator plate?
Old May 17, 2022 | 06:40 PM
RB211's Avatar
RB211
This is how it is supposed to be
Old May 17, 2022 | 07:06 PM
danieljanse's Avatar
danieljanse
Cruising
Thanks a bunch! I can fit it right in there like yours. I'm going to have to bend the bracket a bit but no big deal. Mystery solved!
Old May 17, 2022 | 07:11 PM
RB211's Avatar
RB211
No problem sir! Hope this solves the problem.
Old May 18, 2022 | 03:53 AM
TCFS's Avatar
TCFS
2021 C5 of the Year Finalist - Unmodified
the bracket should not be bent if it is new. It attached on the subframe in press-nuts.
the center of the bracket is leaning against the 2 aluminum pieces for rigidity purpose.
good luck!
it will cool better.
TcFS
Old May 18, 2022 | 12:18 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Yup! You had it in upside down. This will solve your problem.
