Shock absorber questions
For reference, right now (in my '99 hatchback) I have the Z06 shocks and find the ride to be excellent in the city, but once you're doing 75 the pounding is rather unnecessary. The roads here are post-apocalyptic. I plan to use this car as a gran tourer and it will never see a track. Also, the bump steer is a little scary sometimes. The only other aftermarket thing is one of the previous owners put 18/19 on it with hankook V12's instead of the factory 17/18 runflats. Also, I am happy with the rear, there is no tire hop and everything feels settled back there. The fronts pound and dart and high speed.
What I understand is that the GM OE Soft ride is ACDELCO 540514 is the softest, but at $170 a pop I'm unimpressed. I know the Bilsteins get a lot of love here, but I have heard conflicting stories on these forums that they both harder and softer than the Z06 shocks. Also, a lot of the parts say Except Real Time Damping, or wo/o Electronic Suspension, Except F45, etc.
I have whatever came with the 99 base targa top hatchback. There are no switch for anything, there is no ride control, it is equipped with none of those things. The TCS button held down does nothing (no competitive mode). There are no codes. The car is stock height. There is no body roll. I have to push HARD on the corners to move them.
What I'm wondering is what's the type of suspension code I should be looking for (FE1?) and what's the softest to hardest list. Something like
Softest> GM OE ACDELCO, Monroe, ???ACDELCO "Premium"???, Bilstein B6, Bilstein B8 < Hardest
TLDR: What suspension is gonna give me the cushy old man ride on my base targa hatchback with none of the fancy gizmos that isn't the $200 gm ones
Thank you very much.
I bought the non adjustable front shocks 122-TN510 and rear 122-TN705 from Summit Racing. Replace the N in the part number with an S or D for single or double adjustable at Summit to see the various options. The doubles are quite a bit more money but the singles are decently priced IMHO.
I did find some information that they were developed for the 2004 ZO6 but who knows.
They are stiffer than FE1s I had at low speeds, but at higher speeds there is much more control without giving me a beating.
If I had to do it again I think I would get the FE1s for the C6 they are only 70 each on rock auto. I bet it would have fixed my double bounce/increase the feeling of control and kept it old guy everyday soft.
I do have to say with the SACHS shocks I can just fling the car into a turn and it feels great with lots confidence, so they are staying on..........for now
I did a quick check and places like Zip Corvette lists OEM shocks for $400 a set - probably about right but currently not in stock.
An obvious example is that worn-to-hell shocks can be very soft but ride horrendously poorly.
Ultimately since you probably can't test drive 8 different cars with 8 different sets of shocks ....
Your best bet if you are searching for comfort is probably an affordable shock, from a reputable manufacturer, that is generally well regarded by people you know (ideally a shop that works on corvettes), or, failing that, The Internet (full of weirdos who have different requirements than you.) Might that be the comfort-iest Bilstein that fits on a C5? It very well might.
C5 and C6 shocks can be very affordable options (when standard shocks, not an FE option, ie, not adjustable in any way), but the truth is that shock technology is actually quite a bit better in 2022 than it was in 1996, or 2004, or 2005, or whatever. There can be downsides (occasionally, reputable brands have shoddy manufacturing now), but the major upside is that there's been literal decades of tuning valving for shocks for corvettes, such that a modern shock with modern valving set up for the C5/C6 can get you significantly better ride quality at a decent price and decent overall stiffness.
I know F55 is available. They are very pricey. I would not recommend spending $ to replace them with another set of F55 shocks.
. Interestingly the bump steer and other unwanted behaviors just disappear as speed increases and she really buttons down.Thanks folks.
