Hi From St. Louis
Old Jul 5, 2022 | 02:18 PM
STL.Z06's Avatar
STL.Z06
6th Gear
Default Redline super cool
Originally Posted by Vette-kid
that is normal temps for these, I think 225 is the low speed temp. They are rather quiet on low, you won't hear it. The LS motors are designed to run hotter than previous SBC motors. Something to do with emissions I think.
Has anyone tried this
Red Line Supercool Coolant Performance 50/50 Mix
It claims to reduce temps by 20•
Old Jul 5, 2022 | 02:21 PM
Always Red Dave's Avatar
Always Red Dave
Originally Posted by STL.Z06
Hello, I recently purchased a 2002 Z06 it has been garaged & barely driven for 10 years. The car is bone stock. If anyone knows some worthy instant mods, please let me know.
Thanks,
Keep it bone stock and congratulations!
Old Jul 5, 2022 | 03:18 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Welcome to the forum! Congrats on the Z06. As has already been stated, change the tires NOW! The old tires are not safe regardless of tread remaining. Your tires are the single most important part on your car.
There is no reason at all to change the MAF on a stock car unless it is malfunctioning. As mentioned, you can clean it if needed.
Keeping the radiator and condenser clean will go a long way towrds keeping temps down (although going as high as 230 is still in the normal range for these cars). There are some other things that you can do if you want to try to lower your temps. You can retune your fans to come on at a lower temp. Mine are tuned to come on at 199. This will help. You can also get a Dewitts aftermarket radiator. They are pricy, but WILL lower your temps. I wouldn't use any coolant other than Dex-Cool. Dex-Cool can be easily spotted visually as It is orange instead of green.
Speaking of fluids, you don't know when or if any of the fluids have been changed. I would swap all of them, so that you know for sure. I would recommend DOT-4 brake fluid if you plan on any "spirited" driving.
If you plan on driving at night, I would look into aftermarket headlights. Sharp Light Innovations, and KnightDrive TV both have good options. There are other good options for the rest of the exterior lighting both from Sharp Light or from Vette Lights. Although upgrading to LED bulbs for your non-headlights does make a big improvement. I do NOT recommend just dropping LEDs in the stock headlight housing as the light will scatter very badly.
As others have mentioned, MGW is the go to for aftermarket shifters. Some like a C6 shifter paired with a T-Mod box. In addition to a short throw shifter, you migth also want to consider the anti-venom mod. It is practically free, and really does smooth out the shift feeling.
You may want to consider upgrading your suspension as well. Consider upgrading to C6 Z06 shocks and sway bars. These can be swapped in place of your C5 Z06 parts with no modification or adjustments needed.
As far as exhaust, Borla and Corsa are by far the most popular choices. Other than the stock system, they are the only ones that don't have any drone. If you're not all that bothered by a bit of drone, Billy Boat is also very popular. However, exhaust is extremely subjective, so go with whatever YOU like.
That should be a good start. I've spent enough of your money for you! Let us know if you want to go any deeper down the rabbit hole. We would be happy to help with that. Post up some pics of your car. We'd love to see it.
Don't forget to SAVE THE WAVE!!
Old Jul 6, 2022 | 01:21 AM
STL.Z06's Avatar
STL.Z06
6th Gear
Old Jul 6, 2022 | 03:53 AM
jdmvette's Avatar
jdmvette
Night Owl for life
^ clean looking z...lower it
Old Jul 6, 2022 | 11:52 AM
Always Red Dave
BEAUTIFUL Z06 BLACK BEAST! keep it exactly as it is it looks fantastic and save the money keeping it stock!
