WT Jacking Puck?
Old Jul 20, 2022 | 08:06 PM
MertyEOD's Avatar
MertyEOD
Default WT Jacking Puck?
First time Corvette owner and undoubtedly need to buy a set of pucks.
I gotta admit with a price range from 15 to 120 bucks has me perplexed. Is a set for 120 really that much better? Now I understand a machined aluminum set would be worth more because of material cost. Are permanently attached worth it? I found a set of hockey pucks for 10 bucks that would do the trick just like a small block of wood. Is it just the Corvette premium pricing?
Understood that a lot is personal preference, Just interested to hear some different perspectives.
To me, the 15 buck version seems good enough.
Old Jul 20, 2022 | 09:10 PM
MrMcE's Avatar
MrMcE
I got these metal ones for ~$24 last year, works just fine, leave em on.
Amazon Amazon
Old Jul 20, 2022 | 09:16 PM
ThomasR's Avatar
ThomasR
I bought the red ones because they are very easy to see. A small dot of blue loctite on the bolt threads and I keep the Allen wrench in the ashtray. You will need to remove them if you require a tow truck.
Old Jul 20, 2022 | 09:36 PM
MertyEOD's Avatar
MertyEOD
Thanks for the input. Those definitely look like a happy medium. Seems convenient to always have them on. Not sure if I would be in the mood to remove them when waiting for a tow. The Pros and cons of something this simple lol.
Old Jul 20, 2022 | 10:00 PM
ariZona06's Avatar
ariZona06
I have the bolt on 4 puck set from ZL1 Addons. Sure, they cost a bit more at $70 but my Z06 is worth it.
Old Jul 21, 2022 | 09:51 AM
MrMcE's Avatar
MrMcE
Depending on your jacking situation you could puck your jack instead
Old Jul 21, 2022 | 12:43 PM
Dads2kconvertible's Avatar
Dads2kconvertible
https://zl1addons.com/collections/co...vette-jackpads
What extra value do your $83.96+shipping pads provide over the $32.99 set?
Amazon Amazon
(if price is your primary motivation you can pay $99 for the same set from another vendor: https://acscomposite.com/products/co...lift-pad-pucks )
Old Jul 21, 2022 | 02:04 PM
Not4spd's Avatar
Not4spd
Don't overthink it. I use these $32 snap in/stay in place pucks which install in about 5 minutes. Install them, forget about them, and if need be you can remove them.
Amazon Amazon
Old Jul 21, 2022 | 02:52 PM
Hary Gahtoe's Avatar
Hary Gahtoe
Jack Pads on Corvettes were pirated from BMW E36 by Vieco
Ebay has set for $22
https://www.ebay.com/itm/New-Set-4-J...-/232236249419
Mr McE; Amazon now wants $32.99
* A word of caution to owners of lowered C5's. It's going to be hard to jack/lift car on two post lift after installing pucks. Car is now too low for the arms to get under the car without jacking up the rear end subframe raising the car so think about that
Old Jul 21, 2022 | 03:58 PM
MertyEOD's Avatar
MertyEOD
That is a good point about the 2 post lift. I had to drive my vette up on some boards to get the lift arms under it without pucks.
I was just thinking about the comment about the attached pucks need to removed to tow(rollback/flatbed). Is that so you can use j-hooks in the openings to strap it down? I put mine on a rollback(still needed a lot of lumber because it’s so low) and used 8 point straps. Those straps stayed away from the body and better because of unsprung weight. Now that I don’t have a rollback anymore and gotta trailer the vette, I’ll probably use j-hooks in those openings. Sorry went off on a slight tangent.
Old Jul 21, 2022 | 04:30 PM
ariZona06's Avatar
ariZona06
What extra value do your $83.96+shipping pads provide over the $32.99 set? https://www.amazon.com/gp/product/B0978K7N1S
My motivation for purchasing the ones from ZL1 Addons was previous experience with their products. I bought their lift pads, tow hooks, and a few other items for my 5th Gen Camaro. Nice, quality pieces so it was an easy decision to purchase my Vette pucks from them. The link you posted shows the removable type for $84, the bolt-on type I have are $70. 37 Bucks one-way or another ain't gonna break my budget. Maybe a few hundred or so and I might make a different choice.
Old Jul 21, 2022 | 05:15 PM
I have been using a set of snap in BMW jacking lucks on two C5s and now a C7. Works great for me.
Old Jul 21, 2022 | 05:24 PM
ThomasR's Avatar
ThomasR
Maybe the plastic snap in or the ones you do not leave in are a better option.
Old Jul 22, 2022 | 10:55 AM
grinder11's Avatar
grinder11
Where did you buy them, Jack? I custom made 4 of them up at work before I retired, and steel epoxied them in place. Just curious.......
Old Jul 22, 2022 | 12:36 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
I bought some hockey pucks and keep them in the trunk.
Amazon Amazon
Old Jul 22, 2022 | 01:16 PM
MertyEOD's Avatar
MertyEOD
I saw a couple that look like nothing more then hockey pucks with eye bolts thru them. How do you get the “Veteran” banner in your title?
Old Jul 22, 2022 | 02:42 PM
1911tex's Avatar
1911tex
Check his number of posts and tenure....I think he earned the title!
To WT Jacking Puck?
Old Jul 22, 2022 | 02:58 PM
1911tex's Avatar
1911tex
Anyone buy these "genuine C5 Hockey Pucks".......I did. Had them for a while, had not had the opportunity to use them...but tested...yes they fit into the lift pocket, twist and they stay locked in.....
EDIT: I keep them in one of the trunk bins....I would never drive with these installed!
Amazon Amazon
Old Jul 23, 2022 | 08:22 AM
Joe Scafide's Avatar
Joe Scafide
Default Pucks
Used hockey pucks $4.00
Old Jul 25, 2022 | 11:06 AM
Darrell98's Avatar
Darrell98
I agree, used hockey pucks and an eye bolt. I may have $6 invested
