Sway Bar????
With more research I found that it is the normal size for a C6 with the FE1 set up.
So I started thinking 25.5 front 17.5mm rear 8 mm difference what were they going for.
C5 FE1 is 23 and 19.1 so 4 mm diff and that seems to be the about the norm for all other set ups 4mm difference front to rear the ZO6 6mm.
Again 25.5 to a 17.5??????????? I know someone in this group will know the why on this one.
Rear-wheel-drive cars allow the rear of the car to pivot around the front, and as such, they tend to oversteer. By increasing the stiffness of a rear-wheel-drive car's front sway bar you can help to decrease oversteer in a corner. Since, in this case, the rear wheels are driving the car, we want to keep them planted. To reduce body roll, however, the front sway bar can be stiffened without negatively affecting suspension dynamics.
Could be the why reduce body roll but keep the ride FE1 soft
Increasing front roll stiffness increases understeer
Increasing rear roll stiffness increases oversteer
does not matter if it's front, rear or all wheel drive.
As you have probably discovered, the bars are actually: C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear; C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear.
Remember, along with the info you found and that jackthelad and Elektro provided, the bar diameter is only part of the equation. The anti-sway bars are designed to work in conjunction with myriad factors including spring rates; shock jounce/rebound rates; wheel/tire specs; sway bar wheel rate/sway bar motion ratio; etc.
By the way, one of the most common C5 suspension "upgrades" are matching C6 Z06 shocks with C6 Z51 sway bars. Probably hundreds of C5 owners are running that set up as a nice compromise for street driving coupled with some track time.
Best wishes with finding the anti-sway bars that provide the best possible handling for your C5 as you prefer it.
