Torque wrench
Old Jul 23, 2022 | 10:19 AM
ZigZag's Avatar
ZigZag
Default Torque wrench
Hello all, I would like people who know about this subject to give me a line on a torque wrench that I can use to fit into those tight areas at the header where I can get in there sucessfully to tighten header bolts to the 18 lb max that i need. I just am not having any luck getting in there for all the bolts.
Old Jul 23, 2022 | 11:28 AM
jackthelad's Avatar
jackthelad
Isn't it more a case of how long (or short) an extension is needed? Size wise the smallest you can get are 1/4" drive, but they top out at 200 inch lbs, i.e. 16.67 ft lbs. I would say that is pretty close - maybe just an extra tweak when it clicks would do it. You will have to shop for the right size socket.
Old Jul 23, 2022 | 11:29 AM
Fast one's Avatar
Fast one
18 foot lbs is 216 inch lbs so the smallest wrench would be a 1/4" drive torque wrench with at least that capacity. For example, Lowes has a 1/4" drive torque wrench with a 250 inch lb rating and is 8" long for $55.
Old Jul 23, 2022 | 04:05 PM
ZigZag's Avatar
ZigZag
I actually described my issue in correctly. I have a quarter inch torque wrench I'm looking for something, a swivel or extension I can use to get into those tight spots.
Old Jul 23, 2022 | 06:37 PM
grinder11's Avatar
grinder11
I've NEVER torqued my exhaust manifolds OR headers. Never had any come loose, and never stripped any threads, either. Sometimes, you have to develop a "feel" for tightening some fasteners. Some things are just inaccessible for a torque wrench.......
Old Jul 23, 2022 | 07:02 PM
Fast one's Avatar
Fast one
Some things like the fuel line(s) can be disconnected and moved out of the way for better access.
Old Jul 24, 2022 | 09:05 AM
rwcantrell's Avatar
rwcantrell
Pretty sure swivel joints throw your actual fastener torque value to the low side. Unless you do the maths and adjust for the angles. I don't do the maths for that. I did once for a weird home crow's foot setup thing once. But it was hard. I think it was on a motorcycle, those get more mechanical love.
Old Jul 25, 2022 | 09:21 AM
Gordy M's Avatar
Gordy M
Sometimes a set of crows feet will work in those tight places, simply put a similar size nut in a vice and torque it to 18 lb-ft and then change to the crow foot and check to see if it will click at that amount of torque and adjust accordingly..
Old Jul 25, 2022 | 09:35 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
I've never retorqued my header bolts.
But look into a set of swivel sockets:
Old Jul 26, 2022 | 09:39 PM
vette4fl's Avatar
vette4fl
Torquing is not necessary. Just tighten to 1/4 turn before it breaks…
Old Jul 27, 2022 | 12:23 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I use this for torquing my spark plugs. Excellent and accurate tool.
I bought it at Northern Tools.
Old Jul 28, 2022 | 10:05 AM
ZigZag's Avatar
ZigZag
Thanks everyone
Old Jul 28, 2022 | 07:30 PM
grinder11's Avatar
grinder11
Yes. Extensions also do, but to a lesser extent....
To Torque wrench
