High flow cats?
Old Aug 7, 2022 | 01:21 PM
oktx's Avatar
oktx
Default High flow cats?
I have stock exhaust except for Borla S Type II. I like the sound, I just want it a touch louder. Headers are not in my future right now, so will high flow cats make it a touch louder? Thanks!
Old Aug 7, 2022 | 05:40 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Theoretically yes, but in practice not really. Better to save your money and get the headers as that will make a difference.
Old Aug 9, 2022 | 07:24 AM
lt4obsesses's Avatar
lt4obsesses
They probably wont make a huge difference. That said, my problem is the opposite. I bought my '97 with engine swap, big cam, yada yada. I live in an apartment complex. I got new headers and went with hi flows hoping it would quiet it down a little. Not so much, a little, but not a lot.
Now, the catalytic converter is the biggest choke point in the exhaust. Getting a hi flow will improve that flow and thus performance a bit. You can always go with a rear muffler delete or chambered/bullet axle back. The mufflers on my car have a bypass pipe from the from the muffler in pipe to the out pipe, so essentially I'm a straight pipe.
Old Aug 9, 2022 | 09:57 AM
dom04abp's Avatar
dom04abp
I wouldn't hold much weight in the oem cats playing a major factor in performance or sound. At the oem h-pipe sections, the cats have a different inlet and outlet diameter. Also, the inlet and outlet positions are not in line, they are slightly offset. So its not as easy as a swap as it seems. High flow cats wouldn't do enough to keep a P0420/30 engine code from being thrown. You can turn the code off with a tuning software. Still its seems like too much money and effort for little sound or performance gains.
To High flow cats?
