Hello,
I went to get a coffee at a local store, pulled up a little to far into the edge of the side walk (Still learning to park this things clearly), and heard a scrape.
I went back out to check it out, looks like a small crack maybe .5" down the side, right by the turn signal on the passenger side.
I know about bondo, but is there something I can use to just fill the crack? Now I'm convinced I'm going to park a mile away, plus extra cardio?
I use this 3M product to fix a crack in my driver front fender, which is also a somewhat flexible plastic (not fiberglass). Fiberglass repairs wont work on the bumper.
You can get away with normal fiberglass repairs on a urethane bumper as a thin layer allows for some movement. But it will "pop" if hit at all hard. I repaired a pretty major crack in the flex bumper of our Subaru, by scuffing behind the crack, drilling a few small holes either side of it and applying a layer of resin soaked 'glass mat behind the crack. The resin pushes into the holes and they act like rivets. Then on the outside, just make a small groove where the crack is and use Bondo to fill the groove. Then sand and paint the area.
