What's the Truth?
Old Sep 15, 2022 | 11:27 PM
  #41
Smoken1's Avatar
Smoken1
Originally Posted by Eshoremd
2001
Any codes stored?
Old Sep 16, 2022 | 11:20 AM
  #42
JMG2's Avatar
JMG2
Moderator
2001
so you're in luck, the 2001 ebcm is more repairable than the 2000 and older -- it's not repairable in all instances, but it is repairable, as has been pointed out, depends on the code.
there are tons of threads on this topic -- I'm not well-versed in the 2001+ versions, so at the risk of giving you bad advice, I'm not going to say much more than check the forum. there are some really, good detailed threads on this, and I believe information in the sticky.
Also, the better news is that not only was the 2001+ ebcm discontinued later than the pre-2001 version, there are a lot more years' worth of used ebcms out there for 2001+ . check ebay, you''ll see the price for 2000 and older is hitting around $1,500 for an ebcm, the price for a 2001+ is far, far less.
Old Sep 16, 2022 | 12:06 PM
  #43
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by JMG2
what state inspection? most of our cars are over 20 years, even in the north east they're except from everything except a basic safety inspection. Won't even come up.
I'm in western NY, and although my C-5 is now 21 years old, I still have to go through the "annual inspection" hassle. And in NY, there's an electric monitor that gets plugged into the car's onboard diagnostic receptacle, and the pass/fail status of your car, along with it's license plate number, which gets scanned at the beginning of the process, is reported directly to "big brother", at the central DMV office.....
"Slippin the inspector an extra $20 bill" no longer works.
Old Sep 16, 2022 | 12:45 PM
  #44
c5arlen's Avatar
c5arlen
Originally Posted by Mr. Black
I don't have the active handling option. I guess I'm gonna be DEAD.
In Q it's called "dead man walking"... Very apropos GM.
Old Sep 16, 2022 | 01:14 PM
  #45
1985 Vette's Avatar
1985 Vette
I keep hearing about these annual inspections for eastern states and I am amazed at how draconian they are. I would not want those govt drones touching my car for risk of them screwing something up. Emissions testing for all cars ended a few years ago in the SSR of Washington State, but the last time I did an emissions test, they told me to get out of my truck so they could put their OBD2 scanner on my OBD1 1995 Truck. I refused and had to explain to the inspector and their supervisor the diff between OBD1 and OBD2, and that they will need to put their sensor in the tailpipe as they had done in the past.. It was unbelievable
Old Sep 16, 2022 | 01:26 PM
  #46
1985 Vette's Avatar
1985 Vette
Originally Posted by MWWarlord
You still have an EBCM even if you don't have active handling. As stated by others, if it fails, your traction control and ABS will no longer function. You will also have warning lights on in your dash. The car can still be driven. It just isn't as safe. Also, depending on where you live, the car my longer pass inspection. You are correct that if it fails, your options are very limited. Good luck!
If the EBCM fails, does anything else happen besides a warning light and a loss of ABS, and traction control? Does the computer put the engine in limp mode or something like that?
Old Sep 16, 2022 | 02:36 PM
  #47
Fast one's Avatar
Fast one
In NY if the check engine light is on or the codes to turn it off were erased and the GM driving cycle not completed, the car fails. If the driving cycle is done the check engine light will come back on if the problem remains.
Old Sep 16, 2022 | 05:15 PM
  #48
JMG2's Avatar
JMG2
Moderator
actually, I got my wires crossed -- CT (just moved here) is 20 years, NY is 25 years. vehicles older that 25 years old in NY are exempt from OBD diagnostics
New York DMV | New York Vehicle Inspection Program (NYVIP2)
Also, even if you fail diagnostic, you can get a one year waiver and a pass if you pass the safety inspection (visual inspection and gas cap inspection) and spend ~400 in repairs.
Old Sep 16, 2022 | 05:16 PM
  #49
JMG2's Avatar
JMG2
Moderator
no.
Old Sep 16, 2022 | 06:35 PM
  #50
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
I'm so glad here in Maryland if the car is 20 or older you buy Historic tags for like $55 for 2 yrs or something like that. No inspections or emissions ever.
You can be ordered a repair order my police if the vehicle is later than 1985 (Think that's the year) and be required to go through an inspection. I've never heard of that happening though.
Old Sep 16, 2022 | 06:48 PM
  #51
vette4fl's Avatar
vette4fl
Here in the state of freedom there are no inspections and tags are cheap, You may use any brand of clutch and tires, 93 octane and alligators are plentiful…
Old Sep 16, 2022 | 06:55 PM
  #52
JMG2's Avatar
JMG2
Moderator
remarkably, it's the same in CT. I was surprised to find out that afte r20 years, they don't even do a safety inspection.
Old Sep 16, 2022 | 10:07 PM
  #53
~Josh's Avatar
~Josh
Banned Scam/Spammer
Only a few codes can be repaired on ‘01+ there is no safe haven.
All years are out of dealer stock including ‘01+
I bought the EBTCM part number that goes to my ‘01 a few years back and although $600 at the time for a brand new unit wasn’t something I wanted to spend, it’s nice to have on the shelf as I plan to keep the car another 30-40 years and then my son can have it. As of today that price is a steal, glad I got it.
If you’re keeping the car regardless of year, buy the known problem parts now to have.
