Service Column Lock
Old Sep 21, 2022 | 05:55 PM
Webbsite's Avatar
Webbsite
Cruising
Default Service Column Lock
15 years after having the bypass installed, the Service Column Lock message showed up again today. The motor cuts off if I move 2-3 miles per hour. I had it towed to the Chevy dealership. Any ideas, thoughts, solutions, etc.?
Old Sep 21, 2022 | 05:59 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Check the battery, this could be your problem. Good Luck!
Old Sep 21, 2022 | 06:02 PM
Webbsite's Avatar
Webbsite
Cruising
I appreciate the reply. The car starts fine. The battery is less than one year old. I am getting "pull the key, wait 10 seconds" and "Service Column Lock " messages.
Old Sep 21, 2022 | 07:21 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
http://www.complianceparts.com/
This is what you need. Once the Chevy dealer (Rockenbach?) takes a look, you need to install a LCM5. This IS the only permanent fix out there.
Old Sep 21, 2022 | 08:50 PM
Webbsite's Avatar
Webbsite
Cruising
Thanks for the heads up about this product. I will go talk to the dealership mechanic tomorrow.
To Service Column Lock
