Convertible top question
Old Sep 30, 2022 | 12:21 PM
Midiwiz's Avatar
Midiwiz
Default Convertible top question
I just redid my wife's 03 vert. looks much better and I did use raggtop.... but. I had figured after doing the process it would have a different effect or am I missing something? I had thought that the top would bead water rather than just get wet. and nothing .
Did I miss something?
Old Sep 30, 2022 | 01:02 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Not sure why you would think that it would react any differently to water than the OE top. There are a variety of chemical treatments that you can apply to the top to help protect it and make water bead up.
Old Sep 30, 2022 | 01:04 PM
Midiwiz's Avatar
Midiwiz
like?? my other verts beaded up, like it much better. so what products?
Old Sep 30, 2022 | 01:32 PM
1999corvettels1's Avatar
1999corvettels1
Did you replace a vinyl top with a cloth top?
Never had a cloth top but would imagine it would not have water beads.
Old Sep 30, 2022 | 01:35 PM
Midiwiz's Avatar
Midiwiz
vynil???? never seen that one on a vette.... cloth all my cloth tops beaded water
Old Sep 30, 2022 | 01:44 PM
1999corvettels1
My 1999 still has original top and it’s vinyl, guessing later C5 Corvettes came with cloth.
Old Sep 30, 2022 | 03:11 PM
Justin Raney's Avatar
Justin Raney
I had a vinyl top plastic glass 66 fairlane i see they have these cloth top convertible c5s. The cloth looks nicer. Hard to say
Old Sep 30, 2022 | 03:53 PM
v6turbo87's Avatar
v6turbo87
I have a 99 and it is canvas (cloth) not vinyl
Old Sep 30, 2022 | 03:55 PM
Midiwiz's Avatar
Midiwiz
this really isn't a discussion on what comes with what.... geez
v6turbo87's Avatar
v6turbo87
Did you apply RagrTopp protectant after you cleaned the top? It is a 2 step process.
https://wolfsteins.com/collections/c...protectant-kit
Old Sep 30, 2022 | 03:57 PM
Midiwiz's Avatar
Midiwiz
obviously I did say follow the process
Old Sep 30, 2022 | 04:02 PM
grinder11's Avatar
grinder11
I agree. My 2000 still has the OEM top, I think it's called Twillfast? Anyway, the only C5 verts I've ever seen with vinyl tops had aftermarket tops. I'm 99% certain GM made zero C5s with vinyl tops.
Old Sep 30, 2022 | 04:15 PM
Justin Raney
Can you tell what convertible top this is looks like cloth compared to my old 66 vinyl top. Does it look to be original or replaced? The top itself is in pretty good shape if its original from 00 theres a 00 ss beige top thats tore up the back glass fell thru it. Theres blue magic convertible top cleaner and protectant i had purchased for my 66 last year before i sold it. I use to use convertible top cleaner and protectant in different bottle but after being disabled i feel the 2 in 1 is best easiest use.
Old Sep 30, 2022 | 04:19 PM
DW600RR's Avatar
DW600RR
I have this for my Jeep, but also use it on my vert because the top is made of the same Twill fabric as the Jeep top. It makes the water bead and roll off.
Old Sep 30, 2022 | 04:34 PM
1999corvettels1
The white convertible tops on C5 Corvettes were vinyl through all the years, found out from doing some research.
When it’s replaced it will be black canvas.
Old Sep 30, 2022 | 04:49 PM
Midiwiz's Avatar
Midiwiz
oh my god 2 helpful posts the rest...who cares what top was on what?
Old Sep 30, 2022 | 04:51 PM
Midiwiz's Avatar
Midiwiz
often do you have to re-apply it?
To Convertible top question
Old Sep 30, 2022 | 04:55 PM
Midiwiz's Avatar
Midiwiz
Small issue it says for black tops, this isn't black.
Old Sep 30, 2022 | 05:51 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Not sure what went wrong with your process except maybe the product was expired or bad? I have a black cloth top on my 2004 convertible and after I clean it with the Ragg Top cleaner, I then apply the Ragg Top fabric protectant and let it penetrate/dry overnight. The next day, I brush the top and take extra time around the crease points and it looks great and beads water. Just did it last week. Top is 18 years old.
Old Sep 30, 2022 | 06:02 PM
Midiwiz's Avatar
Midiwiz
that's what i did. no beading. I did look at the can...... don't see a date. I can go get another can since 3 coats takes the entire can........ I'll try one from the auto store instead of amazon maybe it's the dates....
