Battery
Old Nov 5, 2022 | 08:55 AM
chevrolee's Avatar
chevrolee
Default Battery
Anyone have a suggestion or preference on a battery for a 2003 Corvette base model
Old Nov 5, 2022 | 09:07 AM
Joe Scafide's Avatar
Joe Scafide
Default battery
Any agm battery
Old Nov 5, 2022 | 09:31 AM
ALLEGRO's Avatar
ALLEGRO
When not driving for a few days, always put a "battery tender" on her. There is quite a bit of parasitic-draw with these rides and keeping the battery topped off with significantly extend the life. I got just short of 10 years (119 months) from my OE cell.
Old Nov 5, 2022 | 09:51 AM
jackthelad's Avatar
jackthelad
Definitely AGM. Odysseys are IMO the best, but are expensive.
Old Nov 5, 2022 | 10:04 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’d go with the AC Delco 78PSHR (Professional Silver High Reserve) battery with a whopping 140 minute RC (Reserve Capacity)…you should also replace both battery bolts since they have a special conductive coating which helps in transfer of energy between the battery and the terminals…part number for side post batteries is 19115561.
Old Nov 5, 2022 | 10:50 AM
JMG2's Avatar
JMG2
Moderator
I've been using optima yellow top for years, with a battery tender. Works grteat.
But yeah, make sure you get an AGM battery.
Old Nov 5, 2022 | 11:23 AM
Z06ster's Avatar
Z06ster
I have used nothing but Optima Yellow Top. My previous one lasted almost 10 years!
Old Nov 5, 2022 | 07:58 PM
MY03C5Z's Avatar
MY03C5Z
Definitely go with an AGM. Odyssey here
Old Nov 5, 2022 | 10:48 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Anything.......as long as it is spelled "AGM"
Old Nov 6, 2022 | 01:32 AM
I used AGM batteries in my last two C5s and they provided great service for many years.
Old Nov 6, 2022 | 10:47 AM
knewblewkorvette's Avatar
knewblewkorvette
Like many have said, AGM is the way to go as they won't leak acid onto the C5's computer. I personally use the Optima Yellow Top and a battery tender. I also have Red Tops as one came with the car and the other for cosmetic reasons
https://www.optimabatteries.com/prod...lowtop-d34-78/
Old Nov 8, 2022 | 05:36 PM
novasscnc's Avatar
novasscnc
Nothing that will leak
Old Nov 8, 2022 | 07:34 PM
Mr31FlavorsVette's Avatar
Mr31FlavorsVette
St. Jude Donor '12
After reading this from their site, is there a reason not to get the red version?
"Use REDTOP for normal engine starting where an alternator immediately monitors the state of charge and provides energy to the battery whenever it is needed.
This would describe most stock vehicles, including: automotive and RV under hood starting, heavy equipment where starting is the primary function, and diesel vehicles without aftermarket electronics.
Use YELLOWTOP when electrical loads are higher than average, or when the discharge cycle is more than typical engine starting, such as vehicles with multiple electronic accessories and vehicles without alternators. This can also include vehicle with a lot of factory electronics such as power sliding doors and a DVD player. Examples also include: racing vehicles without a charging system, dedicated drag racers, diesel-powered vehicles with aftermarket electronics, and vehicles with inverters, winches, underdrive pulleys or other accessories."
Old Nov 10, 2022 | 11:09 AM
JHrinsin's Avatar
JHrinsin
I have been very happy with my Autocraft (Johnson Controls) group 78 AGM battery 740 CCA 115 min 60 Ahr, that I bought at Advance Auto.
Some may insist on a 120 min rated AGM battery, so those would include;
Rural King (Exide) #RK-AGM78 group 78 AMG battery 770 CCA 120 min 60 Ahr
Deka/East Penn 9A78 Intimidator group 78 AGM battery 775 CCA 120 min 55 Ahr
Old Nov 10, 2022 | 02:49 PM
knewblewkorvette
For me the Yellow Top is chosen as I have big aftermarket stereos. So much so, I have a 250 amp alternator in my 02. My two 99s still have the factory alternator though. I've also have gotten longer life out of the Yellow Tops than the Red Tops.
Old Nov 10, 2022 | 03:52 PM
schmuckingham's Avatar
schmuckingham
AS stated numerous times before, AGM whatever it is. I have a yeller top optima in mine.
Old Nov 10, 2022 | 08:55 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I've been using Sams Club Duracell AGM, $190 + tax in my area currently, with no issues.
To Battery
Old Nov 12, 2022 | 04:40 PM
RedC5's Avatar
RedC5
Red Top for me all these years after the original Delco in the ‘98. Looks great in engine bay especially in a red car, and all have performed beautifully. 👍🏻
Old Nov 12, 2022 | 07:29 PM
killain's Avatar
killain
Oldtimer
I just put a Optima Red Top 75/25 in my 2003 Corvette, not expensive and Amazon will do the shipping for it. Same battery I put in my last C5.
Old Dec 4, 2022 | 03:26 AM
jdmvette's Avatar
jdmvette
Night Owl for life
@knewblewkorvette
Link to the 250A alternator in your -02?
