Help needed on C5 purchase
Old Nov 17, 2022 | 01:54 PM
thegeeman's Avatar
thegeeman
5th Gear
Default Help needed on C5 purchase
Hi to all, looking for advice/help, been looking to buy a C5 for a few weeks now, recently came across a clean 2001 C5 coupe with 156,000 km’s. However, there’s a few issues such as; Hud not working, tear in drivers’ seat, climate control is dim, only has 1 key, 1 FOB, and what really scares me is a slight clicking engine sound. I’m mainly concerned about the engine clicking sound. Seller said it’s nothing, he’s always done regular oil changes with synthetic oil and adds Lucas’s oil additive.
Following my research on forums, might be loose rockers, broken spring or pushrods all issues C5’s is known to having.
Called dealer to inquire on clicking sound and price to repair and of course they said had to leave them car for a deep dive to investigate where the sound comes from and only then they could give me a price, Naturally, this makes senesce.
Not sure if I should walk away from deal, ☹
Any help would be appreciated. Thanks again
He’s asking $10,500
Old Nov 17, 2022 | 02:38 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Look at it this way. $10,500 + new engine + HUD repair + climate control lighting repair + seat recover + additional key + additional fob + other things you'll discover.
If that total is less than the value of comparable cars then it's a good buy. If that total is higher than comparable cars it isn't.
Without knowing what's up with the ticking sound I'd walk away. Lots of cars out there don't have that multi-thousand dollar question mark. And if you're considering a dealer to perform the work you're probably not a car person so I'd walk away and find something that's ready to drive right now. Every repair is an additional opportunity for a headache.
Old Nov 18, 2022 | 01:16 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Run.....don't walk!
Too many good ones out there.
Old Nov 18, 2022 | 01:34 PM
APT21's Avatar
APT21
Definitely move on to another option. There are tons of clean C5s you can get into for a lil more. Also, find yourself an independent shop to work with. I hate seeing you list a dealership as your resource for help
Old Nov 18, 2022 | 03:12 PM
vette4fl's Avatar
vette4fl
These issues “may” not be insurmountable. My underlying concern is that the current owner has not kept up the basic maintenance. People who don’t fix things as they go would be unlikely to change oil religiously, etc.
These cars can turn into a money pit, so choose carefully. Depends on your budget and what you’re willing to fix. So, for example, say you’re planning on heads, cam, headers anyway. Well then you’re doing lifters and top end anyway. In that case, work the price down some more. If you want a driver, I’d walk away from this one.
Old Nov 18, 2022 | 07:57 PM
Mc556's Avatar
Mc556
That car might be what you could call a mechanics special if it were priced less.
Personally I’d keep looking unless you want to gamble a bit.
The ticking could be valve train, exhaust leak, injectors or even a bad PCV valve. The big question is if you are ready to dig in a start working on the car from day one. You’ll go broke if you are paying someone else to do it though. Gremlins can get expensive really quick
Old Nov 18, 2022 | 10:56 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
A definite NO.
Old Nov 23, 2022 | 12:11 AM
Alley Oop's Avatar
Alley Oop
this might help...The key to buying a C5 is:
One or two owner car.
Meticulous maintenance w maintenance records.
Excellent condition. Check to be sure car was not abused or tracked.
Nothing whatsoever wrong. Means the owner took care of all problems which means trouble free driving.
Under 50,000 km.
Manual transmission is very reliable. Convertible or FRC coupe.
Preferable to buy 2003 or 2004. HVAC is not replaceable on 1997 to 2000.
2000 and 2001 had ring problems.
Fuel filtres on 1997 to (1999) have the fuel filtres in fuel line, newer have them in the fuel tanks. 97 – 99 have fewer problems with key fob.
For more info on 1997 – 2000 C5’s check this post
Who's happy with their 97-00's????
To Help needed on C5 purchase
