Would like to replace crank pulley to avoid problems down the road. Any recommendations on brands or styles? I see solid or two piece with impregned rubber available. Just drive the car like an old person (no racing or track driving). Thanks.
Replaced my GM Harmonic Balancer with a Summit SUM-C2501 Harmonic Balancer, ARP Balancer Bolt using the installation tool and new crankshaft seal last month at just under 69K miles. This is a big job that should be using a lift and with 2 people if possible. Like I said, if your balancer spins straight without any noticeable wobble, don't replace it.
