C7 wheels
Old Jan 18, 2023 | 11:03 AM
saxtonfwd's Avatar
saxtonfwd
Default C7 wheels
I am sorry if this has been discussed, did some searching didnt see the answer, but looking to buy a set of c7 rims and tires for my c5 vert. The wheels are 20x11 rear a d fronts are 19x9.5. The tires are 315/30/20 rear and 275/35/19 front. What spacers work best? Also will I have to new TPMS sensors or can I use my old ones? Thanks!
Old Jan 18, 2023 | 11:42 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Fronts should be ok but what are the offsets for the rear wheels?
Old Jan 18, 2023 | 11:59 AM
saxtonfwd's Avatar
saxtonfwd
I will have to find out , they are the Cray wheels of the c7
Old Jan 18, 2023 | 03:05 PM
saxtonfwd's Avatar
saxtonfwd
The rear offset is 76mm. And fronts are 56mm.
Old Jan 19, 2023 | 12:31 AM
jdmvette's Avatar
jdmvette
Night Owl for life
for that high of an offset you'd probably need about an inch or 25mm worth of spacer
Old Jan 19, 2023 | 12:55 AM
You should be able to use your existing TPM sensors on the new wheels. Stock offset for rear OEM wheels on a base/Z51 car is 79 mm. So go from there.
To C7 wheels
