2004 fuel filter?
Old Feb 4, 2023 | 11:53 AM
Black_Valkyrie's Avatar
Black_Valkyrie
Default 2004 fuel filter?
Had a pile of work done on the car last week. Mechanic said that the 04 had the fuel filters in the tanks so fuel filter is the one thing that didn't happen. Is this the case? Videos I saw online showed it to be external
Old Feb 4, 2023 | 12:30 PM
rrwirsi's Avatar
rrwirsi
Yep, in the Tank. Just another stupid design from the folks at GM. ​​​​​​​
Old Feb 4, 2023 | 12:54 PM
killain's Avatar
killain
Oldtimer
I wanted to change the fuel filter in my 03 convertible, and I bought one only to find out mine too, is in the tank ! I got a refund though ?
Old Feb 4, 2023 | 02:40 PM
666lisa's Avatar
666lisa
I ton this tons of member till other member u have to maintenance ur car on certain ur damage something times but when its inconvines its put to the side, LOLLOLOLOL
U know that filter is way over do and could lean from slow clogging which u wouldnt even know if u dont have A/R gauge take out a cylinder and bye bye engine just for a 100 buck part good luck.nI do mine every three yrs because i love the work, Getting the gang together and bitching y we do this to ourselves. But some beers later everything is ok. Give it a try.
Old Feb 4, 2023 | 11:23 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Black_Valkyrie
13 hr job... that's a lot of beer.
Old Feb 4, 2023 | 11:32 PM
Smoken1's Avatar
Smoken1
Getting to the filters on the early cars is a lot different than the ones with the FFS fuel system
Old Feb 4, 2023 | 11:54 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i changed my filter when i changed my clutch since it was right there externally hanging out
Old Feb 5, 2023 | 10:47 AM
666lisa's Avatar
666lisa
Yeah but what im getting at is with so many many post about mantanens is curicail then when its hard or to much money they don't change part That is LOLOL. There is no shortest or beer, not like parts for these cars. Just another example that kills me. Is when they a tick or not normal noise in valve train or whatever, they send to oil analyzes comes black with higher than normal of whatever then they say but i think its ok and then spend 3k on an exhaust system or whatever, and others will rebuild. Just saying when inconvenienced anything is sacrificed. SOOOO manitaine is not that important on these cars and over rated.
Old Feb 5, 2023 | 03:33 PM
c5arlen's Avatar
c5arlen
U know.?
Oh I know! I know plenty... I just don't know what you're attempting to say ... Perhaps try one more time.
Old Feb 5, 2023 | 08:41 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Feb 6, 2023 | 12:24 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
To the OP, I can confirm that the fuel filter in the '04 is in fact inside the gas tank. We ALL agree that GM was incredibly stupid to do this. The ONE positive to having to replace my fuel tank on my '04 was that the fuel filter got replaced too.
Old Feb 6, 2023 | 04:11 PM
VERYSOON's Avatar
VERYSOON
My understanding is that the EPA wizards required it along with all the other BS located inside the fuel tanks.
My main bitch about GM was putting fuel senders in the tanks that could not handle being immersed in gasoline!!! DUHHHHHHH
VS
Old Feb 6, 2023 | 04:44 PM
rrwirsi's Avatar
rrwirsi
I agree. It is a filer and that requires changing when dirty like air/oil filters. If you are correct on the EPA requirements then why didn't the GM design geniuses design a reasonable access to replace? Because stupid is as stupid does.
Old Feb 7, 2023 | 09:25 AM
Sojourner's Avatar
Sojourner
The fuel filter is supposed to be life of vehicle, what did GM consider life long?
Most fuel filters are in the fuel tanks in vehicles today...
Old Feb 7, 2023 | 11:00 AM
wydopnthrtl's Avatar
wydopnthrtl
If I were chief engineer for corvette I'd give the DIY'er what he wants. The ability to service your vette yourself using the normal tools a DIY'er would have in their garage.
- Removing the whole torque tube and trans to replace a clutch is ridiculous. (why not just give the ability to slide it rearward, remove the tube and replace the clutch)
- Removing the trans to get to the inside of a fuel tank is ridiculous
- Removing the dash to get to the steering sensor is ridiculous
- The quality of these ABS units (especially on C4's) is ridiculous
- I'd give the vette owner built in lifting pucs
- Low quality vibration dampers and having to remove the steering rack is ridiculous
- Battery acid spilling onto the PCM is ridiculous
To 2004 fuel filter?
