[Z06] Z06 camber adjustments
Is camber adjustable on a Z06 without purchasing parts (upper and/or lower A arms)?
I plan on lowering the car with the bolts tightened all the way (1/2 -1 inch) this weekend, and I was told after a week of driving to get the car re-alligned. I plan on having the dealer do this, but in the process I would like some more additional camber (-1.0) for more aggressive cornering. Can you have this done at a dealer? I do not want to attempt to do this myself, has any body gotten this done by a dealer/performance shop?
http://forums.corvetteforum.com/zerothread?id=464280
also see this thread
http://forums.corvetteforum.com/zerothread?id=468086
Some good advice in both of them. Email me if you would like the entire spec sheet.
From looking at your specs, I note that you give much more camber to the fronts than the back?!? I was thinking 1 full degree of negative camber at each wheel? should I add some camber just to the fronts and leave the rear stock? BMW's actually come out of the factory with negative camber in the rear only? Why? I am a little confused.
