C5 gas door.
Old Mar 4, 2023 | 11:53 PM
drewnahlik's Avatar
drewnahlik
4th Gear
Default C5 gas door.
My gas door button won’t open the door anymore. I don’t know why everything else electronically works normally and there are no blown fuzes. I took the interior apart enough to unhook the button and plug it back in. It still didn’t work. The button still makes the clicking noise, and I haven’t tried replacing it yet.
Old Mar 5, 2023 | 07:57 AM
yellow2007's Avatar
yellow2007
Have someone push the button while you hold your ear next to the door and see if it clicks. Could be the gas door solenoid itself.
Old Mar 5, 2023 | 01:58 PM
rrwirsi's Avatar
rrwirsi
My gas door get lazy and it does not show it release. However, I found it does but just not enough to open. When it happens, I take a plastic card and gently pry it open. The cause is usually dirt and stuff that interferes with the opening. A good cleaning and lube makes it work until the next time.
Old Mar 6, 2023 | 05:33 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yep, this is the way to bet.
To C5 gas door.
