Missing pieces
Old Mar 12, 2023 | 08:58 PM
Komiller118's Avatar
Komiller118
Default Missing pieces
I finally have my new to me C5 on my quick jacks and found what appears to be missing "nuts". Ehat say you experts. This is the lower side of front cross member.
Old Mar 12, 2023 | 09:08 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Mines is on ramps at the moment so here's what it looks like
Old Mar 12, 2023 | 10:09 PM
Elektro's Avatar
Elektro
Yeah those nuts hold your motor mounts down, might wanna fix it. Right now the only thing holding your motor in is gravity.
Old Mar 12, 2023 | 10:11 PM
vette4fl's Avatar
vette4fl
Old Mar 13, 2023 | 12:13 AM
heggsc5's Avatar
heggsc5
Wow. Yeah those are pretty important to have...I'd strongly suggest taking a good look at the entire thing while you've got it up in the air to make sure no other very important nuts or bolts are missing
Old Mar 13, 2023 | 08:18 AM
frodo84's Avatar
frodo84
Uneducated autodidact
It looks like someone used an impact and broke off the studs/bolts....can you see the ends of them?
Old Mar 13, 2023 | 10:16 AM
yellow2007's Avatar
yellow2007
I had the same thought as Frodo...........when I had my C7's torque converter replaced the dealer stripped out 3 of 4 frame bolts in the rear cradle. NEVER start a bolt or nut with an impact wrench........
Old Mar 13, 2023 | 10:48 AM
Komiller118
Studs are there. I could tell where nuts had been attached and could see they were attached to the engine. Just wanted to be sure of what i was looking at.....
Old Mar 13, 2023 | 11:12 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Glad you caught this before it caused a major issue. Good luck!
Old Mar 13, 2023 | 01:31 PM
frodo84's Avatar
frodo84
Are you saying that the cradle is hanging low, off the ends of the studs?
Old Mar 13, 2023 | 05:01 PM
Komiller118
Lower part of engine mounts had no nuts on them where they come through the cradle
Old Mar 15, 2023 | 12:58 AM
Yeah, get that fixed right away.
To Missing pieces
