AGM battery help please
Mar 25, 2023 | 03:08 PM
I’ve been searching for a new Agm battery. Anyone have any suggestions ? Thx
Mar 25, 2023 | 03:30 PM
I bought one at OReilly Auto parts about 2 months ago. They had plenty in stock at the store near me. So far it's been a good battery.
Mar 25, 2023 | 03:41 PM
Optima Batteries OPT8022-091 8022-091 75/25 RedTop Starting Battery
This is the one you want. An Optima "Red Top" AGM. I have this exact battery in my car- no compromises or complaints.
Mar 25, 2023 | 03:43 PM
^ I had bad luck and went thru several red tops.
I think this one is a better bet
Mar 25, 2023 | 04:52 PM
Optima is not what they once were. Don’t know about the yellow the red was junk. I went with the Diehard Platinum AGM that at this point has out performed the Optima
Mar 25, 2023 | 05:30 PM
Quote:
Originally Posted by
Fcar 98
Same here…. Advance Auto Parts purchased the Die Hard line so they’re easy to find.
I’ve been very pleased with it.
Mar 25, 2023 | 05:41 PM
2023 C5 of the Year Finalist - Modified
When I go on Advanced website and enter my car it doesn't give me a Diehard AGM option.
Mar 25, 2023 | 05:48 PM
I recently bought a Duracell group 78 AGM from Batteries Plus. 5 year warranty and they are 20% off often.
Purchased yellow top for my 2004. No complaints
Eshoremd
It probably depends on your location of what your store has.
Mar 25, 2023 | 05:55 PM
Mar 25, 2023 | 06:56 PM
Mar 25, 2023 | 07:46 PM
In 2017 I bought a 26AH Mighty Max battery, Sealed Lead Acid about 1/4 the size and weight of a typical car battery, lay any position sideways
Back then they were like $28 but the price went up since then
Still have it, works like new, cranks over 5.3L from the trunk
Mar 25, 2023 | 08:46 PM
Kirkland is the best bang for the buck, and lifetime warranty
Mar 25, 2023 | 09:02 PM
Eshoremd
This is the one I have… It is slightly larger than your original/stock battery, but fits perfectly in the tray (like the stock one should have). I did have to grind the little rubber hold down a bit, but I got it to fit just right.
https://shop.advanceautoparts.com/we...0051&langId=-1
Mar 25, 2023 | 09:20 PM
Mar 26, 2023 | 04:43 AM
Last battery I purchased for a C5 was a Diehard Platinum AGM - excellent battery.
Mar 26, 2023 | 11:15 AM
Walmart!
Mar 26, 2023 | 11:31 AM
Those old Platinums were rebadged Odyssey Extremes. Mine lasted 14 years. Replaced with another Odyssey. Expensive though.
Mar 26, 2023 | 11:34 AM
ztheusa
Walmart!
Many C5's take a 78 with side terminals. A bit bigger and higher CCA as well.
