Fluid flush
Old Apr 1, 2023 | 11:04 AM
yellow2007's Avatar
yellow2007
Default Fluid flush
OK guys. I've had my 2000 C5 with 44 k miles since December now and it's been mostly garage kept. Looking over the maintenance schedule I see where mileage wise I'm in good shape but at 23 years am way past the time for many things. I'm thinking of having my brake system, rear axle and coolant systems flushed. My brake fluid is rather dark but no issue stopping. I've done my own clutch fluid flush but the rest are outside my wheelhouse now. Would you agree with flushing all the fluids or am I over cautious................?
Old Apr 1, 2023 | 12:13 PM
ariZona06's Avatar
ariZona06
Yes, it's time to change those fluids. If you've bled the clutch system you're certainly capable of doing the brakes. Rear diff is just a drain and refill. So is the transmission (if manual). You can flush the rad with chemicals or just drain, fill with distilled water and drive a day or two then drain and fill with proper 50/50 coolant. Plenty of videos out there and great folks on this forum to help. Driving/maintenance season is here, maybe do one system a week.
Old Apr 1, 2023 | 01:05 PM
yellow2007's Avatar
yellow2007
$ years ago I changed the tranny fluid on my C7. Not a fun job and required a transfer pump and jacking the rear of the car way higher than I was comfortable with. Fast forward and I'm no longer comfortable nor inclined to do my own maintenance anymore. The clutch fluid was just a matter of remove fluid, refill, pump pedal a bunch of times and repeat. My clutch fluid is clear now.
Old Apr 1, 2023 | 01:51 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
I would change any and every fluid, I did so on my 99 C5 - brake, coolant, steering, transmission, diff.
Old Apr 1, 2023 | 11:08 PM
wydopnthrtl's Avatar
wydopnthrtl
Absolutely!! Flush every single fluid.
What sounds odd to me is that you have flushed your clutch fluid. IMO thats about the hardest one to flush w/o a bleeder kit installed.
btw, if your careful to not get any air into the brake system you don't have to cycle the ABS.
Old Apr 3, 2023 | 01:10 PM
Missileboy's Avatar
Missileboy
I just did my brakes last weekend and it was easy peasy with a Motive Power bleeder. Took about an hour and there was alot of junk in the old stuff. You will feel a definite difference in pedal feel after a good flush!
Old Apr 3, 2023 | 02:10 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
+1 for replacing all the fluids.
Old Apr 3, 2023 | 04:07 PM
yellow2007's Avatar
yellow2007
I did the poor mans flush. Removed brake fluid, refill reservoir, pump clutch pedal 20 times and repeat until fluid is all clear...........which I'm happy to report it is now....
Old Apr 4, 2023 | 09:51 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
To Fluid flush
