Intermittent starting
This problem just started - we were on vacation for a couple of weeks, so when I got home wanted to charge up the battery in my 1999 coupe. Stopped to get gas, car wouldn't start, battery ran down, but when I jumped it, it started right up. Fast forward two days later (after putting the battery on a charger) drove two miles to a friends, went to leave and no start. Tried jumping it but still no start. Next day jumped it and it started right up. Again put the battery on charger (only 15 months old) and now am having intermittent starting issues.
Car will try to turn over, but start clicking like the battery is too weak. The security light will blink, First three letter of odometer flash and the gage needles bounce around. I get a low voltage message showing volts 5.4 and I can't enter on board diagnostics. Did hear some buzzing coming from fuse box.
I have replaced:
Battery
Alternator
Fuel system relay
I unplugged the battery overnight to drain the capacitors but did not help. Still can't access OBD, but it did start and run fine in the garage for 10 minutes, then same problem after trying to restart.
I am guessing it is the ignition switch after scouting the net and forums. Does this sound like the issue?
Thanks for any help/ideas.
Thanks for your reply.
You may want to go through and clean all of your ground wires.
I have replaced:
Battery
Alternator
Fuel system relay
