You’ll want to find one with the little loops, like this: LINK
They often seem to come in packs of 2 or 10.
You can get LED versions (you’ll want a twisted loop then, else the light faces the wrong direction), but there was something about them not shutting off when the hood closes, iirc. I’m sure someone else can confirm or correct me on that!
Wasn't there something about needing to be careful when fitting the bulb because if done incorrectly you can short something out? Seem to remember seeing it on a video a few months back but can't find it now!
I have a LED bulb and it shuts off after the specified time if you leave it open.
My led doesn’t shut off when the hood is up. It goes into lower intensity after a while, but not completely off. It shuts off fine when the hood is closed.
