Buying new tires
Old Apr 21, 2023 | 11:17 AM
HeavenlyDemon's Avatar
HeavenlyDemon
3rd Gear
Default Buying new tires
I’m planning on buying new tires, my current ones are 245/45r17 and 275/40r18. I wanna get bigger ones, will 245/55r17 and 275/60r18 fit
Old Apr 21, 2023 | 12:24 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
Taller tires or wider tires? The ones you listed are taller but not wider. The larger the first number the wider, the larger the second number the taller.
Old Apr 21, 2023 | 12:37 PM
HeavenlyDemon
3rd Gear
Taller
Old Apr 21, 2023 | 01:36 PM
MetalMan2's Avatar
MetalMan2
Can't tell if you're serious and/or if there are typos...
Your stock tires are 25.7" & 26.7" tall F&R.
The tires you're proposing are 27.6" & 31.0".
That's a change of 1.9" & 4.3". Yeah, don't do that.
At most IMO only go up one size on the aspect ratio. For front that would mean 245/50/17, rear 275/45/18, making the front and rear about 1" taller.
Old Apr 23, 2023 | 04:28 PM
redzg's Avatar
redzg
As MetalMan is indicating, changing to a taller tire is the same as going to taller rear gears, making a 3.42 accelerate like a 3.15.
Old Apr 25, 2023 | 01:53 PM
c5arlen's Avatar
c5arlen
Do you or don't you care about the handling at speed? Just wondering.
To Buying new tires
