Changing Harmonic Balancer on Quick Jacks
Old Apr 21, 2023 | 07:37 PM
Bubbak's Avatar
Bubbak
Default Changing Harmonic Balancer on Quick Jacks
I have a question about changing the harmonic balancer while up on quick jacks. The QJ seem really stable but when you need to torque the HB will it be stable enough? Anyone done the HB change while up on QJ? Thanks for any comments. Bob
Old Apr 22, 2023 | 08:30 AM
Markolc1981's Avatar
Markolc1981
I've worked with Quik Jacks and they are rock stable. IMO right up there with a 2-post lift. Certainly better than jack-stands.
Old Apr 22, 2023 | 09:54 AM
ThomasR's Avatar
ThomasR
Yes. It's fine.
Old Apr 22, 2023 | 09:57 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Not only have I done it before I've done it three times before.
If you are worried about it lower the car back down so the wheels are touching the ground and then torque from the top.
I prefer to torque from the top anyways so there is more swinging room. I personally skip the torque wrench and just use a 36" breaker bar and pull until I can't pull anymore.
Old Apr 22, 2023 | 10:53 AM
Markolc1981
If you manage to knock the car off the quick jacks (assuming it's supported properly) then you've torqued too hard lol.
Old Apr 22, 2023 | 11:48 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
My crank bolt was a bitch, and sure rattled the car, but the QJ's still would have been fine.
Old Apr 22, 2023 | 01:53 PM
Justin Raney's Avatar
Justin Raney
I did it on two walmart 10$ jackstand under the front. Undid the rack, tie rods,abs bracket, block and the rack slide out the passenger side halfway enough to change the balancer, cam swap not too bad maybe 2-4 hours changing a balancer or front seal whatever youre in there doing.
Old Apr 22, 2023 | 05:46 PM
walleyejack's Avatar
walleyejack
I always place a cpl jack stands under the qj after it is up. maybe over kill, i know the lock system is in place,
but just me.
Old Apr 22, 2023 | 05:51 PM
Mr. Black's Avatar
Mr. Black
but just me.
That's all fine and dandy but if they topple over laterally I won't matter.
Old Apr 23, 2023 | 09:07 PM
v8srfun's Avatar
v8srfun
When I did mine I put my feet up against the wheel and that eliminates the side load on the jack
Old Apr 24, 2023 | 10:28 AM
grinder11's Avatar
grinder11
Just use an air, or strong electric impact to remove. I've used an air impact to R&R my balancer for almost 20 years, off and on 3 or 4 times for different cams. Never came loose. Don't use an impact on the stock bolt for tightening!! Use an impact to tighten only on an ARP bolt. My .02.
Old Apr 24, 2023 | 02:23 PM
sayerbloke's Avatar
sayerbloke
That’s interesting; I’ve heard of not using one to tighten but didn’t realise that maybe it was related to the choice of bolt.
Old Apr 25, 2023 | 10:27 AM
grinder11's Avatar
grinder11
Yes, stock bolt is torque to angle, and can't be reused. For all the torquing and angle measuring hassle the stock bolt needs, just get an ARP bolt, and use an impact. I guarantee a shop will use an impact to remove the old stock bolt. If you ever need to 'go back in there,' the ARP will pay for itself the first time this happens. My .02....
Old Apr 25, 2023 | 10:53 AM
schmuckingham's Avatar
schmuckingham
I think the QJ should be good for the balancer removal/install. I removed the entire driveline on a set.
Old Apr 25, 2023 | 02:03 PM
Davcruz's Avatar
Davcruz
I did mine on Quick Jacks, it was no problem at all. Very solid. However, just due to the height, when it came time for torquing the ARP bolt, I set it down to almost touching the floor.
To Changing Harmonic Balancer on Quick Jacks
