I have a 2000 base conv, I do not track the car but where I live in East TN has a lot of fun mountain roads between TN, NC, & GA that ask for aggressive driving some times.
My question is now I need to do a brake job which is the better brake set up Powerstop Z23 or Z26?
Thanks in advance for any feed back.
Neither is going to be super great for actual performance driving. I have the Z23 rotors. I used to have the pads that come with it, but the pads don't have great bite, and are VERY prone to heat soak. The same is true of the Z26 as well. The Powerstop rotors are fine, but If I were you, I would consider Hawk HPS 5.0 pads instead. They dust a lot more than ceramic pads, but the performance is night and day better.
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
Carbotech brake pads can be ordered by calling me at 216-780-8825 Or order direct Here Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per – Amp'd Autosport Use promo code z28 at check out for your forum discount.
Part number f or the C5
F: CT731 1521
R: CT732 1521
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
I have used stop tech pads, a couple of sets Hawk HPS pads, never used hawk 5.0 pads, recently installed hawk HP plus pads, and stainless steel brake lines. Let me tell you from experience, the hawk HP plus pads are night and day difference from the stop tech and hawk HPS pads. The car bites hard and will stop harder than the other pads. Hawk HP plus pads do make a little noise because it’s about the closest thing you can get to an entry level race pad. I don’t have enough miles on them to comment on dust. Point being, hawk HP plus pads bite the hardest out of the pads that I have used. I can’t comment on carbotech pads either, never used them. I’m currently sold on hawk HP plus pads.
