Rec 91 fuel.......
Old Aug 5, 2023 | 06:14 PM
grinder11's Avatar
grinder11
Default Rec 91 fuel.......
Most of us have heard of the Rec 89 or Rec 90 fuel for seasonal vehicles. No alcohol in it, but it isn't cheap. Last week, the wife and I were in Michigan's U.P. (Upper Peninsula) and needed gas. Found a station with regular@$3.27/gallon. I looked at the pump's fuel options and was really surprised to see Rec 91! Never heard of it! Even more surprising was it went for $4.07/gallon!!! Down here in the "Lower," I've never seen Rec 91 octane fuel. The Rec 89 and Rec 90 fuel is going for $4.50+/gallon. If you're from Michigan, you'll quickly realize how screwed up these prices are. The U.P. ALWAYS had considerably higher prices than the lower, NOT CHEAPER prices. Never!!! Until now. I looked 2 days ago at that same station I'm talking about, and it has only jumped to $3.38/gallon, still much cheaper than anything in the Lower. BTW, our daily driver, a Buick Encore, ran just dandy on that $3.27/gallon regular. I wish they had Rec 91 down here where I live. At $4.07/gallon, I'll bet it works just fine. Anyone tried this in their C5?....
Old Aug 5, 2023 | 06:22 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
I think the manual calls for 91 or higher, so you should be fine to run this, Ethanol-free is a plus.
For me, I usually run Sunoco Ultra 94 or ExxonMobil 93.
Old Aug 5, 2023 | 09:47 PM
vette4fl's Avatar
vette4fl
Do our cars even have ethanol sensors?
Anyway, the 91 non-ethanol gas should generate more energy/power per volume.
Old Aug 6, 2023 | 12:19 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Mike, I use Rec 90 in my boat and a lot of stations down here have this fuel since there are many boats in my county….actually more registered here than anywhere in the entire country…a station down here has 92 octane non ethanol which I use in the Corvette…non ethanol is the fuel to use if the car is not driven much…and yes it’s pretty expensive!!
Old Aug 6, 2023 | 08:40 AM
Never tried Rec 91 fuel and do not recall ever seeing it offered in this area.
Old Aug 6, 2023 | 08:51 AM
yellow2007's Avatar
yellow2007
I've seen it here recently. I use E85 in my Impala exclusively but there aren't many stations that carry it. I may try the ethenol free in the vette since it doesn't get used much.
Old Aug 6, 2023 | 03:29 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Nope, they do not.
Old Aug 6, 2023 | 03:34 PM
fparkin's Avatar
fparkin
that all i use in my 84 is rec gas 91 from a store call bacon-bridge in michigan
Old Aug 6, 2023 | 03:35 PM
C5 Diag's Avatar
C5 Diag
Originally Posted by Stingroo
Nope, they do not.
You are correct !!
To Rec 91 fuel.......
