[Z06] headlight dimming????
Old Jan 21, 2003 | 06:48 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default headlight dimming????
My car is completely stock and occasionally at night I notice to headlights gets dimmer then they return to normal a second or two later. It ocurs most often when changing between gears but also on occasion while just cruising.
Has anyone else experienced this? Or is my alternator/voltage regulator faulty?
Anyone with an underdrive pulley set experience low voltage/charging issues?
Old Jan 21, 2003 | 09:31 PM
GEAUX's Avatar
GEAUX
Default Re: headlight dimming???? (Z06ufgrad2002)
Try the battery connections. I had one do that because the neg. connection was loose.
Old Jan 21, 2003 | 09:36 PM
oderja's Avatar
oderja
Default Re: headlight dimming???? (Tod2K)
both my 99 and 01 coupe did the same thing I really never found out why I the dealer couldn't find anything wrong either. I haven't driven the 03 Z06 enough at night to see if it does it to.
Old Jan 21, 2003 | 10:04 PM
wt2ga's Avatar
wt2ga
Replace the stock battery with an Optima Red Top and the trouble goes away.
Old Jan 21, 2003 | 10:37 PM
Gaijin's Avatar
Gaijin
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
I get it too and same with the instrument lighting (especially noticeable with the radio).
Old Jan 21, 2003 | 10:40 PM
RPO_Z06's Avatar
RPO_Z06
St. Jude Contributor
Default Re: headlight dimming???? (wt2ga)
:iagree: :yesnod:
Old Jan 21, 2003 | 10:56 PM
larrysb's Avatar
larrysb
The charging system in the C5 is very slow to respond. Lights will dim momentarily anytime a large electrical load turns on, like the AC compressor, rear defog, when the windows hit the stops, brake lights come on and so on.
Check your battery connections to be sure, but it might be chalked up as normal for C5.
Old Jan 21, 2003 | 11:05 PM
E RACER's Avatar
E RACER
I have noticed it at slow speeds, but never gave it any thought. I'll check the battery connection.
Old Jan 22, 2003 | 02:45 PM
jwight's Avatar
jwight
Cruise-In I Veteran
St. Jude Donor '08-'09-'10
You can try searching the archives. I believe the last time this was going around it was traced to the air pump cycling off and on.
Old Jan 22, 2003 | 04:10 PM
mqqn's Avatar
mqqn
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Z06ufgrad2002 -
I notice an electronic "brown-out" of the lights occasionally - I hesitate to take it in for this alone, but I will mention it in the spring when I take the Z in for some other little annoyances -
let us know if you resolve the issue -
best regards -
mqqn
Old Jan 23, 2003 | 10:13 AM
Waterfreak's Avatar
Waterfreak
Default Re: headlight dimming???? (mqqn)
Both cars do it on occassion.
Old Jan 23, 2003 | 11:04 AM
Pipefighter's Avatar
Pipefighter
Default Re: headlight dimming???? (Waterfreak)
Yep, on the 01 when I had it. I suggest as others, change the battery. :seeya
Old Jan 23, 2003 | 02:05 PM
hiyield's Avatar
hiyield
As I have had almost every issue regarding the Z06, the dimming issue is a daily. Mine occurs when I hit the brakes typically. Apparently Chevy is aware of the problem but there is no fix according to them. It is possible that a better battery will help. My alternator whines upon acceleration so I believe that there is an overall electrical problem anyways. On occasion my whole display goes completely dark for a split second too. :confused:
Deeb
Old Jan 23, 2003 | 03:03 PM
Waterfreak's Avatar
Waterfreak
Default Re: headlight dimming???? (hiyield)
Deeb
My alternator whines also, and I had the black display first time a couple of days ago, just for a second. I thought I was seeing things out of the corner of my eye.
Old Jan 23, 2003 | 08:45 PM
hiyield's Avatar
hiyield
Yeah-it was a real joy the first time the display went dark-driving on the 95 and I though my car was shutting down. Pretty much know that there is an alternator problem since they just replaced the battery and still same problem. I told them that if I get stranded I'm going to track down Lou Bachrodt at home to pick me up... yeah sure.
Just another Z06 oddity to throw on the heap--- :skep:
Dee
Old Jan 23, 2003 | 08:50 PM
viperZ06's Avatar
viperZ06
That's vette, both of mine do it!!!
Old Jan 23, 2003 | 09:57 PM
Scott-2002-Z06's Avatar
Scott-2002-Z06
Default Re: headlight dimming???? (kgrif)
I have also heard that if you change the battery the problem will go away, but if i remember correctly the Z06 has a special battery to reduce weight, at least that's what they said in the video!
:cheers:
To headlight dimming????
Old Jan 26, 2003 | 01:28 PM
drs's Avatar
drs
I Notice a slight dimming from time to time with both of mine, and both have Optima Red Tops.
Never had the display go black though. If that ever happened at the wrong time, it would make for some adrenalin production :crazy:
Old Jan 28, 2003 | 05:43 PM
jimstem's Avatar
jimstem
Where did you get your battery and did you install it yourself? Were there any "fit" issues with putting it in the corvette? Will it fit in a 2003 Z06?
Old Jan 31, 2003 | 06:52 PM
Z06ufgrad2002
OK I took to the dealer to have them look at it and they said basically it a GM problem that not only applies to the C5 but other models as well. Seems as tho GM just doesn't have a handle on the charging system. Guess I will have to bite the bullet and try a Optima Red Top at my expense :cry
