Dumb Question?
Old Oct 24, 2023 | 11:47 AM
snaitaz@aol.com's Avatar
snaitaz@aol.com
Default Dumb Question?
So looking ahead as I progress to my pseudo rebuild/repairs/mod, I want to go LED or HID for everything possible. Undecided as to which way to go but reading all about the hyper-flash connection I only have a couple of questions. Is it needed for both the HID and LED? Is only one hyper-flash connection needed and where is the best place for it to be installed. I guess that was 3 questions. TIA and cheers!!!
Old Oct 24, 2023 | 12:01 PM
Missileboy's Avatar
Missileboy
only one hyper flash module for the LED's you add, and it mounts under the dash to the right of the steering column. A bunch of video's on Youtube on how to install. Super easy and all you need is a phillips screwdriver to remove the panel under the steering wheel to get access to where you plug in the hyper flash module. HID's will come with a ballast you'll add up around the headlight bay. Most HID's that are made specific for a certain car will come with ballast install location recommendations.
I installed a hyper flash module as I have LED DRL's, rear blinkers and marker lights and the blinkers all flash at the correct rate-
Old Oct 24, 2023 | 12:16 PM
snaitaz@aol.com
Well I found this on Amazon for $7. Seems you can adjust the frequency to match the OEM flashing.
https://www.amazon.com/Dewkou-Flasher-Adjustable-Electronic-Motorcycle/dp/B0CBTYB462/ref=sr_1_9?keywords=c5%2Bcorvette%2Bhyper%2Bflash%2Bmodule&qid=1698162849&sr=8-9&th=1 https://www.amazon.com/Dewkou-Flasher-Adjustable-Electronic-Motorcycle/dp/B0CBTYB462/ref=sr_1_9?keywords=c5%2Bcorvette%2Bhyper%2Bflash%2Bmodule&qid=1698162849&sr=8-9&th=1
Old Oct 24, 2023 | 02:04 PM
DetroitGS's Avatar
DetroitGS
Hyperflash Harness - Amazon:
Amazon Amazon
Hyperflash Harness - Vette-lights:
https://www.vette-lights.com/collect...-flash-harness
Hyperflash Harness Install:
Old Oct 24, 2023 | 02:11 PM
snaitaz@aol.com
Hey Detroit that was easier than I thought it would be. Thanks for the video. Cheers!!!
To Dumb Question?
