Leaking Convertables
Old Nov 11, 2023 | 02:24 PM
grinder11's Avatar
grinder11
Originally Posted by Cfive4life
grinder11 - I appreciate that. I will try the dielectric grease
Just don't use too much grease!!! Don't ask!!!!!
Old Nov 11, 2023 | 02:38 PM
Cfive4life's Avatar
Cfive4life
Haha. I will be careful and only consider this an experiment. I'm looking for a permanent adjustment/fix without workarounds.
Old Nov 11, 2023 | 07:33 PM
Alley Oop's Avatar
Alley Oop
Like that's helpful.
The op wanted to know about leaks. Now he knows that some don't.
Old Nov 11, 2023 | 07:52 PM
Cfive4life's Avatar
Cfive4life
Yep, it's confirmed, you're a genius.
Looking for serious replies from those who know all the possible adjustments for the windows and the top's frame itself. They're the only wildcard here because the top and every seal is new.
Old Nov 11, 2023 | 07:59 PM
Alley Oop's Avatar
Alley Oop
The original question was " For those of you that have had a C5 convertible, is it common for them to leak?"
A genius??? That will be disputed by many.
Old Nov 11, 2023 | 10:07 PM
helphos's Avatar
helphos
My 2003 AE Vert has the original top and doesn't leak. I plan to replace the top soon, because it's old and nasty, but it doesn't leak!
Old Nov 12, 2023 | 12:37 PM
grinder11's Avatar
grinder11
Not to play Mr. Obvious, but the vast majority of leaks aren't from the top, per se. They are from old, worn weatherstripping. To be clear, my occasional drips are not from the top leaking, they're from old weatherstripping no longer sealing correctly...
Old Nov 12, 2023 | 12:40 PM
grinder11's Avatar
grinder11
Another possibility is badly worn door hinges that may make window/top adjustments unable to compensate enough I've never adjusted my top, so can't help there..
Old Mar 17, 2026 | 02:19 PM
ILoveFridaC5's Avatar
ILoveFridaC5
Cruising
I have the same problem. I also need help. We may be the only ones with a water leak. Is there anybody out there who can offer a solution? .
Old Mar 17, 2026 | 06:54 PM
hyperv6's Avatar
hyperv6
Look you need to locate the leak. Then you check is it an adjustment issue, a seal issue or a is the roof damaged.
Most areas like the front latches can be adjusted as can the windows. Now if the frame is bent, roof is damaged or seal is damaged it may need repaired.
take it to a shop tgat does tops and they can address it.
I got caught in a storm where 3” of rain came gown in the natter if minutes. I had not had the car in the rain but I looked around and nary a drip came in. If it had a leak it would have showed it during that storm.
General leaks are on the side glass and the window or seal needs adjusted if at the header the the latches or seal need adjusted.
Old Mar 17, 2026 | 07:16 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
The number 1 thing to do to prevent leaks is to apply dielectric grease to the seals once a year. I've had issues with leaks on my ''04 twice since 2013. The first time was shortly after I bought it. I didn't know what I was doing and I went through and gave the whole car a very thorough and deep clean. In the process, I cleaned all the grease off the seals. Both advice I got on the forum and my owners manual told me to apply dielectric grease. This COMPLETELY fixed the problem for a few years. As shocking as it is, I have found that dielectric grease solves at least 75% of leak issues. My other leak was caused by the rear window starting to detach. This is a known issue with the verts. It is a design flaw. However, when I got the top replaced, they corrected this issue, and my rear window now has a lifetime warranty. As others have mentioned, there are also a number of adjustments that can be made. When I first bought the car, we didn't have a garage. Other than the issues mentioned, it stayed water tight outside during a freaking hurricane. If you want a convertible, don't let the fear of leaks stop you. Like so many things with the C5, if you take good care of it, it will take care of you.
Old Mar 17, 2026 | 07:22 PM
Smoken1's Avatar
Smoken1
This thread shows how to adjust the top
https://www.corvetteforum.com/forums...-and-tips.html
Old Mar 22, 2026 | 12:06 PM
  #33
RPGR90s's Avatar
RPGR90s
My 2000 Vert is remarkably leak free. I am **** about treating all the rubber seals every year as well as cleaning and waterpfoofing (spray) for the top itself.
Last summer, I got caught in a big storm (about 150 miles) and it was dry and warm inside.
Old Mar 22, 2026 | 12:47 PM
  #34
ILoveFridaC5
Cruising
Baby steps first. Yes, I believe your advise to be right on. I ordered Nextzett Gummi Pflege Stift to revitalize all of the weather stripping. Delivery is 4/3. I bought the RaggTopp Cleaner and Fabric Protector Kit. Weather permitting, I'll be servicing the rag top. Any comments or advice on my approach to problem solving? I am a rookie. My Vet is a 2003 50th Anniversary with 37K miles. It was well kept. Right now, it needs some TLC. Never owned a rag top before. My 69 and 88 were both T's and Targas.
Old Mar 23, 2026 | 08:10 AM
  #35
hyperv6's Avatar
hyperv6
A top done right should not leak. If you have a leak it is a seal or adjustment issue. Most common are window adjustments. If needed seek professional help as it is often much easier and cheaper in the long run.
Old Mar 23, 2026 | 01:32 PM
  #36
MWWarlord's Avatar
MWWarlord
It should be mentioned that you should never take a convertible C5 through a commercial carwash. Honestly, I would avoid taking ANY C5 through a commercial carwash since it's bad for your paint. Even "touch less" carwashes will blast your paint with small particles that came off the cars that went through before you.
I'm getting off topic though. It is counter indicated to take ANY cloth top through a commercial carwash. It has nothing to do with leaking in the wash. It puts undo wear on the top and over time will actively damage it.
Old Mar 23, 2026 | 01:40 PM
  #37
ILoveFridaC5
Cruising
Thanks. That is an excellent reminder of the damage that can be done. How about a home pressure washer? Is it OK to wash and rinse with a wide fan from a safe distance?
To Leaking Convertables
Old Mar 23, 2026 | 02:05 PM
  #38
MWWarlord's Avatar
MWWarlord
I'll admit I'm not a pressure washing expert. However, I would generally avoid using any high pressure applications on the top. I hand wash mine, and use a garden hose to rinse it when done. There are a variety of cloth top cleaning and protecting products out there. Just follow the directions on the container.
Also don't store the car with the top down, or put the top down when wet
Old Mar 23, 2026 | 03:31 PM
  #39
ILoveFridaC5
Cruising
More good advise. Garden hose it is. However, top up when wet; down when dry.
Old Mar 23, 2026 | 06:58 PM
  #40
hyperv6's Avatar
hyperv6
To be honest you should never car wash a Vette. The tracks can catch on some lowered cars. The mirrors can be damaged as C5 mirrors are not the strongest.
touch-less is not hood as they use harsh cleaners that strip wax. Most used recycled water.
best thing to do it park it in the rain and sit inside or get someone to hose it around windows and seal.
The factory puts all cars in a water booth and dumps a ton of water on each car to check windows and seals.
