OEM C5 Window Regulators Still Available?
Old Nov 5, 2023 | 09:51 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default OEM C5 Window Regulators Still Available?
Well, based on the grinding sound, it might be time for me to replace my 20 year-old driver's side window regulator. In searching online, a few GM sites list the OEM part as discontinued. As a result, does anyone know the OEM GM Part # for the driver and passenger window regulators? (Might as well grab a passenger one as well for when that motor gives up the ghost).
If the OEM GM regulators are no longer available, can anyone recommend a good aftermarket version?
Thanks!
Old Nov 5, 2023 | 10:29 AM
jcgunn's Avatar
jcgunn
The OEM regulators were a generic (POS) part and fit several GM vehicles. Try Rock Auto.
Old Nov 5, 2023 | 07:56 PM
RTHACKER's Avatar
RTHACKER
I installed the Dorman I got from O'Reilly and worked great. Hardest part is not breaking parts taking off the door panels and buttons. Was around 150 dollars if I recall.
Rob
Old Nov 5, 2023 | 08:36 PM
ttiros's Avatar
ttiros
https://www.gmpartsclub.com/window-regulators
Old Nov 5, 2023 | 08:47 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I just put in the cheapest highest reviewed Amazon special into my factory original drivers door in my 97 with only 40k miles on it.
The GM ones are junk. The new one is very nice. Smooth and quiet.
Just go straight to Chin er and be done with it.
Old Nov 6, 2023 | 06:40 AM
MSG C5's Avatar
MSG C5
Originally Posted by ttiros
No results when I enter the 2004 Corvette so they must be discontinued.
Old Nov 6, 2023 | 06:43 AM
MSG C5's Avatar
MSG C5
That's where I will go next. In reviewing some install videos online, some mentioned that the aftermarket ones won't last as long so that's why I thought OEM. Even if they are junk, the first one lasted 20 years so I hope to never have to replace the new one I install. More concerned with getting the smooth and quietest one available.
Old Nov 6, 2023 | 08:55 AM
charriman's Avatar
charriman
4th Gear
Yeah.. discontinued. Dealership replaced mine with one from Auto Zone.
Old Nov 6, 2023 | 09:47 AM
tabbruzz's Avatar
tabbruzz
I bought the following one from Amazon....It was 54 bucks and works fine.....good reviews too...
YHTAUTO Front Left Driver Side Power Window Regulator with Motor for Chevrolet Corvette 1997-2004
Old Nov 6, 2023 | 08:36 PM
MSG C5's Avatar
MSG C5
Thanks for all the input. I ordered the Dorman regulators from Rock Auto as they had lower prices than Amazon.
Old Nov 6, 2023 | 08:40 PM
Mr. Black's Avatar
Mr. Black
At least you got a grinding sound lol.
Mine went from working perfectly to grind pop stuck down in one button push.
In all seriousness though, I think you will be shocked at how easy this job is. That is why I guess I don't care if I run no name units.
With all my tools laid out I'm confident I could replace one of these in 20 minutes.
Old Nov 6, 2023 | 09:48 PM
MSG C5's Avatar
MSG C5
Thanks for the pep talk. I've had my door panels removed on many occasions for various mods, upgrades, etc., and the scariest part is not breaking any of the plastic tabs, connectors, etc., when removing the panel. I've watched a couple of You Tube videos already and it looks pretty straightforward once you remove the insulation barriers, etc.
Old Nov 7, 2023 | 07:33 AM
Good luck with the repair. Hope the new regulator lasts at least as long as the OEM one did.
To OEM C5 Window Regulators Still Available?
