C5 led interior
Old Jan 4, 2024 | 06:05 PM
Raymond Shartrand's Avatar
Raymond Shartrand
Default C5 led interior
I am ready to change out my interior lighting to LED. Who can recommend a good LED bulb kit that will include all of the interior lights?
Popular Reply
Jan 4, 2024, 09:37 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Contact Vette Lights. I don't see a complete kit on their site but they have every light you need and they are a forum vendor @VetteLights
Old Jan 4, 2024 | 09:37 PM
Dads2kconvertible
Old Jan 4, 2024 | 09:38 PM
killain's Avatar
killain
Oldtimer
Cole @ vette-lights, he put together for me and it is stunning !
Old Jan 5, 2024 | 12:43 AM
Also try Sharp Light Innovations - also a forum vendor. Both come highly recommended.
Old Jan 5, 2024 | 09:39 AM
MSOH's Avatar
MSOH
Veteran: National Guard
I have used a mix of both Vettelights and SharpLight for all my bulbs inside and out. Very happy with the results all the way around.
Old Jan 5, 2024 | 10:24 AM
Raymond Shartrand
Default C5 Led interior
Thanks for all the great responses for my questions about the LED interior lights. I have a set on order and I will let you know how it turns out after I get them and install them.
thank you everyone for your help.
Old Jan 5, 2024 | 01:17 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Good luck with the install and please post pics post installation. One small piece of advice is to not over bulb the application with super bright LEDs. I added a set to the door switches and they were too bright and basically distracting when driving at night.
Old Jan 6, 2024 | 09:42 PM
C5VetteKing's Avatar
C5VetteKing
Veteran: Marine Corps
You're going to see a huge difference when these LEDs light up your interior!!!
Old Jan 7, 2024 | 03:22 PM
MSOH's Avatar
MSOH
I can agree here! The LED I installed that illuminates the MPH/KPH display on the gauge cluster is so bright it highlights the Check Engine Light icon! At first I thought I actually had a CEL illuminated, but soon realized I didn't otherwise it would have been brilliantly illuminated. One of these days if and when I have the gauge cluster out again I will remedy that.
Old Jan 7, 2024 | 07:29 PM
Raymond Shartrand
Default C5, LED interior
Thanks for the advice on the cluster lights and the door lights. The kit that I got is for the map, lights, hood, light, rear, cargo lights, and front foot areas for passenger and driver,& license plate, lights I will take pictures of before and after. 👍🙏
Old Jan 9, 2024 | 05:34 PM
Raymond Shartrand
I’ve got the interior lights changed out to LED. The rearview mirror lights were the most difficult ones, I just removed the mirror, because it was much easier to work on. The problem I am having is with the under hood LED light. When the lights time out and go off. The LED under hood goes from bright to half power. If I put the halogen light back in when the interior LED lights, go off the under hood light does go off, drawing 0 V. When the LED light goes to half power it’s drawing 5 V. I’m assuming this LED under hood light is not, does not have enough resistance?
Old Jan 9, 2024 | 05:41 PM
yellow2007's Avatar
yellow2007
Tip: remove the rear view mirror. makes install of bulbs easy
Old Jan 9, 2024 | 07:23 PM
Raymond Shartrand
Default C5 led interior.
New underhood light led is not working properly. It started full bright, but when the lights timed out to go off the interior lights, go off, but the under hood light goes to minimum power and is still partially lit. If I close the hood, it goes off, but when I raise it, it goes back to low power. I put the halogen light back in and the under hood light works as it should. When the halogen light shuts off, I measure 0 V across the terminals. When the LED light goes into very dim mode, I measure 5 V across the terminals. I’m guessing it’s the low resistance of the bulb?
Old Jan 10, 2024 | 02:45 PM
jjc508520's Avatar
jjc508520
I have some LED installed - note that if you don't do the radio as well it stays dim while everything else glows...
Old Jan 10, 2024 | 02:52 PM
Raymond Shartrand
are you referring to the under hood light?
are you saying I need to do the radio lights so the under hood light will operate properly?
Old Jan 10, 2024 | 03:34 PM
jcgunn's Avatar
jcgunn
The timer circuit and mercury switch in the underhood light don't seem to work well with LEDs
Old Jan 11, 2024 | 09:27 AM
Raymond Shartrand
I agree. Since taking voltage measurements with the original light and the LED light, I can see your point. I’m thinking of installing a harness with a switch, then I can shut off the under hood light when it’s not being used. I will let you know how that works out when I do it.
To C5 led interior
Old Jan 29, 2024 | 01:03 AM
douglasjre's Avatar
douglasjre
What do the map light LEDs look light, how do I install, and where do I get them from ?
Old Jan 29, 2024 | 03:03 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
This thread is a good resource for interior lighting questions ---> NEW Interior LED Mod Thread
Old Jan 29, 2024 | 10:34 PM
douglasjre's Avatar
douglasjre
What's the solution if you don't have the festoon bulbs but instead the three color LED thingies? They're not bright and the color sucks. I sure want to change those out
