[Z06] Catch can install
Old Feb 4, 2024 | 08:28 AM
captain vette's Avatar
captain vette
Default Catch can install
After removing the TB to clean it I notice the inside of the intake manifold to be oily I can see and touch oil on the wall so I decided to pull the trigger on a catch can.
Old Feb 4, 2024 | 09:25 AM
MSOH's Avatar
MSOH
Veteran: National Guard
I did that exact same thing last fall, haven’t pulled it yet to see how much oil it has captured.
Old Feb 5, 2024 | 12:00 AM
Ran an Elite Engineering catch can on my last two C5s - did a great job catching the oil vapor and keeping the oil from going into the intake.
Old Feb 5, 2024 | 08:22 AM
captain vette
I’ve good experience with Elite catch can from my previous C6 GS
Old Feb 5, 2024 | 02:56 PM
smitty2919's Avatar
smitty2919
Never a bad idea to add a CC to any car.
Old Feb 8, 2024 | 08:59 PM
JHrinsin's Avatar
JHrinsin
Installed mine after I swapped in the '04-05 LS6 valley cover and the LS2 throttle body on the TPIS modified LS6 intake manifold. I also used the C6 LS2 bellows for a factory look. Had to use the LS2 hose routing diagram.
Old Feb 9, 2024 | 08:31 AM
captain vette
how come the oil filler cap shows 0/40. Very nice engine though
Old Feb 9, 2024 | 08:40 AM
JHrinsin's Avatar
JHrinsin
Late C7 oil filler cap. Due to bearing clearances the engine actually requires 15w-50 all the time, but I can't seem to find a cap with that on it, that will fill. The C8 Z06 has a 5w-50 cap, but not sure that will fit either. I just don't want to have 5w-30 mistakenly added.
Old Feb 9, 2024 | 11:10 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Hahaha - from experience - if any of you start hearing a whistling noise when your engine come to low rpm when out driving? Audible indicator the can is FULL because you forgot to drain it over almost a year of daily driving.
Old Feb 11, 2024 | 12:32 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
^^Good to know as I am adding one to mine. My Jeep lets me know when the CC is full with some preignition to go along with the CLOUD emitted from the tail pipe.
To Catch can install
