Choosing offset?
Old Feb 18, 2024 | 05:00 PM
Turkey Lips's Avatar
Turkey Lips
8th Gear
Default Choosing offset?
What are the best wheel offsets for the C5? I want to go 20"rear and 19"front. Wanna order rims online but need to know what works best. Any help with photos would be great. Thanks
Old Feb 18, 2024 | 05:32 PM
Missileboy's Avatar
Missileboy
There is no best, it's how do you want the wheels to look IRT the fender/body lines. I have a 19/18 set up and use +56mm on both and they sit flush to the arch lines (don't stick out). The 20/19 set I spec'd out used +51mm offsets front and back. Call the rim dealer and talk to them about fitment.
Old Feb 18, 2024 | 09:34 PM
DetroitGS's Avatar
DetroitGS
I'd suggest browsing the 'C5 Custom Wheel & Tire Database' at the link below, see what you like in the pictures. Also, check out the 'Seeking Wheel/Offset Guidance' thread below. In post #3 of the Seeking thread, you'll find a list of Corvette OE wheel offsets. You can use this info and the Wheel Offset calculator at the link below to figure out what you'd like:
C5 Custom Wheel & Tire Database:
https://www.corvetteforum.com/forums...your-info.html
Seeking Wheel/Offset Guidance:
https://www.corvetteforum.com/forums...-guidance.html
Wheel Offset Calculator:
https://tiresize.com/wheel-offset-calculator/
Old Feb 18, 2024 | 10:19 PM
LWSZ06's Avatar
LWSZ06
You need to specify a wheel width to get an accurate offset.
The wider the wheel, the more offset is need to have the same backspace.
To Choosing offset?
