tpms problem
Old Feb 19, 2024 | 02:46 PM
Mitch45's Avatar
Mitch45
Default tpms problem
My front 2 sensors were not showing pressure , so i tried relearning did nothing . Pulled a wheel and removed the sensor to be sure which sensor I needed . Just tried learing the new ones , still nothing . My fobs work fine . Any ideas , I will add the battery was low when I tried the new ones but as I said the fobs work .
Old Feb 19, 2024 | 07:24 PM
bookyoh's Avatar
bookyoh
From your description it sounds like 2 are reading correctly and 2 are not. The 2 that are not, do you have just the ”L” and “ R” reading on the DIC or do you have “XX”. When was the last time you knew all 4 sensors reading correctly? With 2 good and 2 bad, it seems worn out batteries in the sensors is the most likely. How old are your sensors? Lots of Forum members seem to have at least 10 years with OEM sensors but I do recall some reporting only a few years with some aftermarket ones.
When you tried to program the 2 new ones, were they the ones triggered by a strong magnet (like the OEM sensors) or with a triggering tool?
Old Feb 19, 2024 | 09:56 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Sounds like new TPMS sensors are in your future.
Old Feb 19, 2024 | 10:44 PM
Mitch45's Avatar
Mitch45
I got my 98 in 2013 replaced the sensors and receiver with the 2001 to 2004 version . so yes it has been at least 10 years since they were installed . Yes I use the round magnet . I will retry the new ones in a day or two once the battery has a full charge.
Old Feb 20, 2024 | 03:40 PM
yellow2007's Avatar
yellow2007
What tool are you sing to relearn them? a TPMS tool or a earth magnet?
Old Feb 20, 2024 | 07:18 PM
bookyoh's Avatar
bookyoh
I think if my car had this issue and I wanted to trouble shoot, I would start the FOB programming with the two rear wheel sensors that are still working. The car does not actually know which wheel is which so just start with the 2 rears even though it is asking for the fronts. Lets say those 2 program and then you get to your new sensor and it won’t program. This tells you your tpms system is probably OK but your new sensors are not OK, or your new sensors are the ‘97-‘00 version, or you require a triggering tool rather than the magnet.
Old Feb 21, 2024 | 03:42 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
Not to hijack, however I just replaced all four wheels and tires along with 4 new TPMS sensors. I now get no reading on any of them, no XXX just blank. I assume I have to trigger them and I also assume I probably have to use a tool vs a magnet. Sound correct?
Old Feb 21, 2024 | 04:48 PM
bookyoh's Avatar
bookyoh
My recent experience with AC Delco OEM style sensors was a blank was due to not triggered. The tire shop who installed them last Summer said I just needed to drive it a few miles and then they would read. I was pretty sure he was wrong but I said OK and headed home with the blank reading (only showing the "L" and "R"). I got home, triggered them with a magnet because they were OEM style, and all was good.
Old Feb 21, 2024 | 06:12 PM
1SharpGent's Avatar
1SharpGent
Mine are the same, but I don't really worry about it. I find it amusing that watching enough youtube videos, you soon realize everyone starts their C5 and clears the TMPS error from the dash immediately. It seems like everyone's got it.
I'm getting new rear tires next week and I'll try the magnet on all four corners to see if I can get them all to read. If not, I'll just stay in the "welp, this is just the car's character" club.
Old Feb 21, 2024 | 07:45 PM
cdee63's Avatar
cdee63
^^ That is where I am heading. My ritual now is hit the reset button to kill the "service vehicle soon" (EBCM is fried), TMPS and then go. I will try the magnet, if that does not work eff it. This is the first vehicle to have TPMS I have owned, not like I am used to monitoring it.
Old Feb 22, 2024 | 10:02 AM
grinder11's Avatar
grinder11
Maybe I've been lucky, but Ive never had this happen......Yet!
Old Feb 22, 2024 | 11:34 AM
Rick369's Avatar
Rick369
If you are installing new TPMS sensors, I would disconnect the negative battery cable for 10-15 minutes after you install the new sensors. I had an issue when I had new tires and new Schrader TPMS sensors installed on a 2004 convertible I previously owned. The local tire shop had problems getting all 4 new sensors to sync and the front left sensor kept getting a reading of XXX. They said to drive it for a day and see if it syncs. Well drove it 50 miles that day and no change. I read on this forum that disconnecting the negative battery cable clears old data that maybe affecting the new sensors from syncing properly. The next morning I disconnected the negative battery cable for 15 minutes. After reconnecting all tires showed 0 tire pressure. Went back to the tire shop and they used their tool and all 4 tires synced up within seconds and showed correct tire pressure. Never had a problem after that.
Old Feb 22, 2024 | 12:44 PM
Missileboy's Avatar
Missileboy
Mid year last year I installed new tires and rims along with new TPMS sensors on my 02. I could not get the magnet to work for crap. Bought a 9 dollar tool on Amazon and it works exactly as it should. Seems as though some of the sensors need that active TX signal to reset them vice the magnet. Anyway, only 9 bucks.
Old Feb 22, 2024 | 12:52 PM
Beast's Avatar
Beast
Not to hijack the thread either, but all of you that are getting TPMS sensors replaced by a tire shop, everything should be reprogrammed before you leave. None of you should have to do any of this at home, unless your replacing your own TPMS in your own garage and mounting and balancing tires, and spend the extra 50 dollars on TPMS sensors known to work with the C5. When they don’t work you get new ones, that’s it.
Old Feb 22, 2024 | 04:25 PM
cdee63's Avatar
cdee63
^^ I agree with that, except... I bought my tires and wheels from Get Your Wheels. Tires were mounted, balanced and sent to my house from CA, I live in Florida.
Old Feb 23, 2024 | 08:52 AM
Missileboy's Avatar
Missileboy
Same here (different vendor) but only issue I had was the magnet just wouldn't work on mine. The second I used the active transmit tool, each corner would "beep" within a second or two of me triggering the tool. And I had a large donut magnet that could lift pounds, it just wouldn't trigger the sensors.
Old Feb 26, 2024 | 01:08 AM
Good luck getting the sensors to sync with the car.
To tpms problem
Old Feb 27, 2024 | 12:35 PM
Missileboy's Avatar
Missileboy
Once I used the active Tx tool, I had no issues with the sensors registering and syncing properly. They actually read my pressures pretty darn close to the air gauge.
Old Feb 27, 2024 | 01:43 PM
oktx's Avatar
oktx
Anyone have a link to the sensors you are using?
Old Feb 27, 2024 | 04:33 PM
Mitch45's Avatar
Mitch45
I have tried using the magnet . I have tried using the relearn tool ( i believe it is model EL 50488 ) I have tried useing both at the same time . I disconnected the battery for 24 hrs . That did turn all the readings to blank . Nothing is working , so I put the old sensor back in and inflated the tire .Done pissin with it .
I put 4 new sensors in my 08 Impala . 3 of them are fine , one just kind of pops up random numbers . As high as 84 psi , as low as 7 psi .
I guess i am not ment to have working tpms . So far my Colorado is still functioning ok .
