[Z06] Piston slapping
With an aluminum block the slap tends to go away upon reaching operating temperature. With a cast iron block, they tend to do the opposite, getting louder as the engine warms.
below 30 degrees it's real loud 55-60 not to bad 70-80 I can still hear it, but just. The sound stops at about 100 degrees oil temp.
Generally as long as it goes away quickly you will be fine.
Older cars can also have blocked passages.
Nothing specific on the LS but something to consider. People have lost a rod or main with a change.
The metering orifices in hydraulic lifters, for instance, are designed for the use of a specific oil viscosity. Deviating too far from the recommended viscosity oil can have a meaningful effect on how your valvetrain operates.
Also, thicker viscosity oil does not necessarily provide better wear protection. First of all, lower viscosity oil more easily penetrates between moving engine parts and modern additive packages provide better wear protection than your grandfather's engine oil. Modern 0W-8 oil, properly formulated, can provide better engine protection, assuming that your engine's internal components have the appropriate clearances and calibrations to use it. Just because an engine oil has the same flow characteristics of water, this does not mean that it has the same lubrication properties of water.
If the theory that a higher viscosity oil will quiet an aluminum engine with piston slap (where the slap is typically more prominent when cold), then it would seem to me that you might want an oil with a higher resistance to flow when cold. Therefore, instead of going from a 5W-30 to a 5W-40, a 10W-30 may be a better approach? This assumes, of course, that you don't live in a geographic area where a higher cold viscosity will interfere with your ability to start the engine in Winter. That said, I have never tried this approach, so I wonder if anyone has actually tried this strategy and, if so, what your results were.
They adjust cam timing. Cool pistons and other key parts with oil They lube turbo bearings and more. Because of all the things they are doing now they need specific things in oils to do it.
There has been difficulties between the oil MFGs and the Auto MFG not always agreeing on what is needed so they came up with the rating to force the oil companies to meet their specs.
In old engines there was just a few basic things oil did and most of it was to lube the crank, rods and cam. Also to leave enough in the cylinder to stem wear and valves.
The LS is one of the first engines to start to use these measures. They cool the pistons with oil due to the higher compression to help stop detonation of higher cylinder temps. Other engines do even more now.
I have sat in with Lake Speed in some training and he knows his stuff. Thicker is not always better. If you want to make changes it is worth a call to the oil company you are using for recommendations. Just changing today is not always a good thing.
Oil has become very high tech and also todays engines the way they are build need them.
