oil pressure sensor relocation kit
Old Apr 8, 2024 | 05:25 PM
link9a's Avatar
link9a
Default oil pressure sensor relocation kit
It's worth to do relocation kit or no even I change the oil sensor already before a year ? Because I'm going to remove the manifold that why l ask this question ...
Old Apr 8, 2024 | 06:51 PM
DDaaryl's Avatar
DDaaryl
If you like removing manifolds the relocation kit is not necessary. On my last C5 I drilled a hole in the plastic above the sender as described in several videos. No regrets. When my next one fails, I would do that again.
Old Apr 8, 2024 | 10:04 PM
jdmvette's Avatar
jdmvette
Night Owl for life
The sensors fail every several years or so. Yes the relocation kit is worth it.
Don't go take a doorknob hole saw to your cowl
Old Apr 8, 2024 | 10:07 PM
link9a's Avatar
link9a
Originally Posted by jdmvette
the sensors fail every several years or so. Yes the relocation kit is worth it.
pjdbm's Avatar
pjdbm
I did the kit and added a gauge, no regrets
Old Apr 9, 2024 | 09:34 PM
If I needed to change to oil pressure sensor, I would go ahead and do the relocation mod. Makes any future changes an easy job.
Old Apr 11, 2024 | 02:59 PM
vette4fl's Avatar
vette4fl
I put a remote sensor with gauge together but didn’t install it yet. Even if the sensor only lasted 7 years, would the convenience vs the oil leak potential from all the fittings be worth it? On the other hand I haven’t heard of these leaking, it’s just my paranoia from racing experience over many years.
Removing the intake manifold is a small job, so I’m not concerned with a “maybe someday” repair presenting itself. Although…I would like the convenience of a mechanical oil gauge situated in the engine compartment.
If you decide to install the remote line, buy the parts individually for half the cost with better parts. I can send you a list if want.
There is also the choice of a brass Buick sensor vs a steel Chevy sensor. Here are a couple choices for layout:
Old Apr 11, 2024 | 03:12 PM
smitty2919's Avatar
smitty2919
I don't like adding more fittings than needed for possible leaks. It's a 15min job to remove the manifold on a C5...
If we were dealing with an LT1 motor in a F-body...different story.
Old Apr 11, 2024 | 03:50 PM
bookyoh's Avatar
bookyoh
Please do post a parts list. Thanks!
Old Apr 11, 2024 | 06:20 PM
vette4fl's Avatar
vette4fl
This is a simple version with gauge. Steel or aluminum adaptor, depending on Chevy or Buick sensor. Complete setup with no gauge/gauge fitting is $68, with gauge and port $111. Without gauge, this is a tad more than half of the kit sold on Amazon, but with superior components.
My recipe specifies Aeroquip hose. As the name implies, they make aviation components, and….they are way less expensive than crap Earl’s hoses. The picture depicts a 12” hose, but you can get other lengths, including 6”.
If you’re buying a sensor look carefully at the manufacturer name, because off brand junk will often list the GM or ACDelco part number.
Chevy sensor:
Buick sensor:
Old Apr 11, 2024 | 08:08 PM
pjdbm's Avatar
pjdbm
You also can add an extension to the harness so it gives you more options in where you mount it.
Old Apr 11, 2024 | 09:23 PM
vette4fl's Avatar
vette4fl
A divided hose is another option. Allows the sensor to be accessible to the original harness, while having the flexibility to mount the gauge where visibility is optimized.
Old Apr 11, 2024 | 09:43 PM
Smoken1's Avatar
Smoken1
^^ I added another 10 inches to the harness
Old Apr 13, 2024 | 11:37 AM
link9a's Avatar
link9a
Great ...👍
Old Apr 13, 2024 | 02:52 PM
c5arlen's Avatar
c5arlen
Yesterday I had that sensor replaced by a Corvette privateer... a pro.... The labor and parts along with an oil change was only 700 bucks... While he was struggling with that job I sat on my couch watching the Masters... 😊
Old Apr 13, 2024 | 04:43 PM
vette4fl's Avatar
vette4fl
Old Apr 14, 2024 | 02:07 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Once you relocate it you'll most likey never have to replace it again. Mines been going strong with no leaks ever since relocation back in 2007.
To oil pressure sensor relocation kit
Old Mar 19, 2025 | 10:11 AM
n2x4's Avatar
n2x4
8th Gear
I just bought the parts for this and wanted to say thanks for the list and a few notes to help others out. I went with the "GM Sensor without a gauge" The Vibrant Performance Adapter was hard to find, even with the notes. I noted the actual part number which should make this easier to find in the future.
Evil Energy -6 AN Female to -4 AN Male, Aluminum, Black (Amazon)
Vibrant Performance Adapter -6AN male to 16mm x 1.5 Female Metric Straight Aluminum (VPE-16786 part number at Summit Racing)
Aeroquip 12" brake line FBPA0040-12 (Was out of stock everywhere, went with SUM-220302 at Summit Racing)
AC Performance, Aluminum Oil Pressure Adapter 1/8 in. NPT female to 16mm x 1.5 male (Amazon)
AC Performance AN to NPT straight Aluminum black anodized -4 AN 1/8 in. NPT (Amazon)
(You'll also need the Chevy Oil Pressure Sensor, but I had one already for the project)
Old Mar 19, 2025 | 11:35 AM
redzg's Avatar
redzg
Perhaps you might share this pro’s name and location?
Old Mar 19, 2025 | 01:00 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
I'm in the wrong business. 700 clams is a PAYDAY for that job. I also agree once relocated it will probably never leak again, mine hasn't in 2 years after the leaky one I originally replaced failed in 2 months (AZ Duralast).
There are several ways to do your own kit, here is my parts list with included mechanical gauge.
Earls AT9919BFJERL - 4AN male/ M16x1.5 male. Fitting at engine original sensor threaded into.
Earls AT304604ERL - 4AN 45deg hose end. Hose end fitting at engine adapter
Earls 303004ERL - 4AN hose.
Earls AT318004ERL - 180deg hose end. Hose end fitting at gauge/sensor.
Earls AT981604ERL - 4AN to 1/8" NPT male straight adapter. Fitting between hose and tee fitting
Earls AT991701ERL - Tee fitting - 1/8" NPT female. Tee fitting for gauge and sensor
ICT F125NPFM1615 - 1/8"NPT male/M16x1.5 female adapter. Allows OEM sensor to be threaded on to tee fitting.
K Motor mechanical oil pressure gauge - screws into 1/8' NPT leg of tee.
I also used a cushioned cable clamp to hold it all in place.
