Convertible Top
Old 04-15-2024, 02:16 PM
jbree
7th Gear
jbree's Avatar
Default Convertible Top
Anyone have any luck with Forever Black Convertible Top Dye ?
My top is slightly faded black , looking to darken it .
Old 05-01-2024, 10:42 PM
helphos
helphos's Avatar
I used a Brtish dye I found on Amazon. It worked great for me. I used it on my shale top (which was mildewed) to spruce it up. Then I used it on my wife's black BMW top which also came out well.
Good luck!
Old 05-01-2024, 11:34 PM
Hary Gahtoe
Hary Gahtoe's Avatar
If you use a fabric dye it will darken the color. Unfortunately it will also change the look to a flat or dull look.
Old 05-02-2024, 06:26 AM
hyperv6
hyperv6's Avatar
Good luck!
I saw a video with that top dye. I wondered if it worked as well in real life.
It looked to do a good job.
Note this is a special top dye and water proofing that is not regular fabric dye.
Old 05-02-2024, 08:17 AM
jbree
7th Gear
jbree's Avatar
Thanks , I've decided to let it be for now and just go with Raggtop treatment.
Old 05-02-2024, 08:36 AM
hyperv6
hyperv6's Avatar
I would try it first as you can always do the latter.
The English dye was on Youtube. I can recall the name but it looked good. I have a new roof and just logged it in my memory for when it may be needed.
Old 05-02-2024, 09:42 AM
RichSilvestris
RichSilvestris's Avatar
Define faded.
In 2016, I tried Renovo Reviver, which is made in the UK.
The process went well. The top got a little darker, and the color didn't show any brush strokes. It's been nearly 8 years and the coating has not gone sour in any way. It did not, however, get rid of the dreaded "stretch marks". This was when I figured out that the fold marks on a top are the result of losing the velour-like "fur" in those places. The marks aren't discoloration, just a more reflective surface.
If there's a product out there that can solve that, I'm all ears.
Left side done
All done
Dried and fold marks still there
The following 2 users liked this post by RichSilvestris:
hyperv6 (05-02-2024), jbree (05-02-2024)
Old 05-02-2024, 10:21 AM
Hary Gahtoe
Try the C2/3 forum. They have a lot of experience with reverse aging
Old 05-02-2024, 11:02 PM
JMG2
Moderator
Support Corvetteforum!
JMG2's Avatar
Received 1,060 Likes on 562 Posts
You could also bring it to an upholstery shop -- local guy was able to refresh mine, I kept it for years before replacing it. Even if you replace it though, it's really not that expensive. Even in the NE, when I did mine it was only around $1,500 -- likely a lot less elsewhere in the country.
@Hary Gahtoe Good idea, the only problem is that the c2 (and I'm pretty sure the c3s) have vinyl tops, differnet process than the twillfast on the c5 (I actually replaced the vinyl on my '67 with twillfast, looks a LOT better, purests be dammed :-) )
Hary Gahtoe (05-03-2024)
To Convertible Top
Quick Reply: Convertible Top
