Quarter-Million Miles
Old Apr 30, 2024 | 03:11 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Quarter-Million Miles
Hit 250k on my '01 vert today
~Dave
Popular Reply
Apr 30, 2024, 03:41 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
Nothing major. Original engine/trans/driveline. Clutch @ 90k because of throwout bearing leak. Starter at 195k. Radiator around 220k. Balancer around the same time. Periodic brakes & tires. Oil pressure sensors. Front air dams last around 75k before snow/ice chunks kill them.
Old Apr 30, 2024 | 03:25 PM
LiManZ06's Avatar
LiManZ06
Wow! In that time, what major work have you done to the car? Engine/trans/diff replacement? Torque tube?
Congratulations on hitting such a major milestone
Old Apr 30, 2024 | 03:41 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
Old Apr 30, 2024 | 04:48 PM
rrwirsi's Avatar
rrwirsi
Your number of repairs at mileage is fantastic. At 50K, that I bought at 32K, my M6 04 vert fun car (never tracked or driven insanely and driven less than 5K per year) has had a HB replaced, wheel bearings replace, oil sending unit replaced, motor mounts replaced, radiator and hoses replaced. head light motor replaced, and ignitions switch replaced. Compare that to my previously owned 92 Acura Legend that I bought with 45K and sold at 298K with only one issue outside of the normal expected maintenance (tires/brakes/fluid changes,etc.) that needed sorting out: AC leak. But, I love driving the C5.
Old Apr 30, 2024 | 06:04 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Congrats on a Quarter-Million Miles, that's awesome.
Post some pictures of your 2001 Convertible. How is the paint and interior?
Old Apr 30, 2024 | 06:48 PM
User 81424's Avatar
User 81424
Congrats. As far as I know, you're the second one to 250K.
Old Apr 30, 2024 | 08:53 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
That's great - 2x 200k+ mile C5's discovered this week!
Old Apr 30, 2024 | 09:21 PM
Beast's Avatar
Beast
Congrats, keep driving her, she’s a keeper.
Old Apr 30, 2024 | 11:23 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
That's a frickin' awesome milestone. Hope it keeps givin' without taken too.
Old Apr 30, 2024 | 11:35 PM
Beast's Avatar
Beast
I only have 82,000 on mine. I wish I had 150,000-200,000 on it, I love to enjoy it. My bro drives me to work, I have 2 kids, the vette is not family friendly, my kids hate my loud exhaust, but I’m not getting rid of her. My c5 was my first wife, first real sports car, and first vette, (original owner.). I drive her when I can. Doing road America this Sunday, and a road rally with SCCA on May 18th.
Old May 1, 2024 | 10:35 AM
Missileboy's Avatar
Missileboy
that just goes to show, driving cars and putting miles on is better than non-use as the parts and pieces stay lubed and used more. Look how many trucks are running around like that, they are always used. Sure, some wear parts will go out sooner from high miles, but overall, that is awesome!
Old May 1, 2024 | 10:39 AM
Fastclient's Avatar
Fastclient
Congratulations on obtaining moon car status. I would say your list of repairs is pretty impressive for that amount of miles . Just gives testament to how good these cars really are.
Old May 1, 2024 | 10:43 AM
acroy's Avatar
acroy
Very nice!
Old May 1, 2024 | 10:46 AM
Mc556's Avatar
Mc556
These cars are capable of staying on the road a long time if maintained. The cars are absolutely solid outside of the interior
Old May 1, 2024 | 11:39 AM
hyperv6's Avatar
hyperv6
What really kills these cars is pure abuse or neglect. Keep them right and you are rewarded.
Old May 1, 2024 | 02:02 PM
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
That's by no means an exhaustive list of repairs up there, but it's not a long expensive list. Nor is this, but it includes:
  • I think one wheel bearing might be original
  • Replaced the A/C compressor (noisy bearing, just as easy to pull the whole thing as to replace the bearing)
  • Intake manifold oil leak around 200k miles
  • Been getting a P1415 air injection code recently (ignore & reset) and an O2 sensor code on occasion (ignore/reset)
  • Headlights were replaced once, I think
  • An A/C tube wore through
  • Driver seatbelt wouldn't maintain ratchet tension
  • Top leaks more in carwashes than it used to
  • Door panel reflectors and those annoying little screw covers fell off
  • Driver seat left bolster seam is just starting to separate
  • A chunk of concrete put a hole in the oil pan (welded to fix)
  • A different chunk of concrete blew out a rear tire
  • Installed a column lock bypass widget
  • Installed an electronic turn signal switch because the hazard switch is such a POS (replaced a few of those)
  • Replaced the tire pressure sensors last year
Otherwise, it's Mobil 1 oil change every 10k miles (burns about 1 qt per 5k miles). I think I changed the spark plugs around 100k.
Not the most recent pic. Needed a bath.
Old May 1, 2024 | 02:20 PM
SilverC54me's Avatar
SilverC54me
My 02 Coupe is at 215k. Have done the following on it,
Harmonic Balancer and timing cover seals/crank seal
AC rebuild
Rear main seal
torque tube couplers, just did that this past weekend
Oil pressure sensor (2x)
rear wheel bearings and tie rod ends
EBCM early on in its life
Steering position sensor, have to do it again after ~100k miles
then there is the usual maintenance item, oil changes, brakes, tires and batteries
Then there are the fun items
just swapped in a 3.42 diff
Z06 sway bars
DRM Bilstein shocks
LED interior and exterior lighting
Custom stereo system
and other item
Gary
To Quarter-Million Miles
Old May 1, 2024 | 03:33 PM
forpetessake38's Avatar
forpetessake38
Absolutely. I don't envy these people buying 20+ year old vehicles with barely any miles on them. None of these are collector cars, drive them!
Old May 1, 2024 | 04:07 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Congrats! Way to drive it!
Old May 1, 2024 | 09:12 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
That’s wonderful, SO glad you drive the corvette rather than just look at it. Keep up the good work.
