ATI Balancer for ls1, ls2, ls3
Old Jun 3, 2024 | 03:31 PM
TorchRedLegend's Avatar
TorchRedLegend
Default ATI Balancer for ls1, ls2, ls3
I recently brought a ATI Super Damper with AC for my c5 that’s about to get cammed. I was told it’s for ls1, ls2, ls3 is there a way to tell for sure before my car goes in? Here are some pictures of the balancer
Old Jun 3, 2024 | 06:42 PM
Dads2kconvertible's Avatar
Dads2kconvertible
You can look at the part numbers on the ATI page.
Old Jun 3, 2024 | 06:48 PM
Markolc1981's Avatar
Markolc1981
I have an ATI, but mines only a 6 rib. Yours has 8. Is that what you wanted?
Old Jun 3, 2024 | 07:31 PM
TorchRedLegend
I see no part number just the SFI Spec 18.1
Old Jun 4, 2024 | 11:46 AM
TorchRedLegend
I just wanted to make sure I have a balancer that will fit because I know some won’t
Old Jun 4, 2024 | 03:24 PM
schmuckingham's Avatar
schmuckingham
917246 is the correct one with A/C. It is a two piece balancer.
Old Jun 4, 2024 | 04:38 PM
TorchRedLegend
So the one I have isn’t correct? I contacted ATI to for some help
Old Jun 5, 2024 | 08:14 AM
schmuckingham
With no part number to go off of, who knows. I was just trying to give you a number to look for on the balancer. If it is two piece there are two sets of bolts, the ones that hold the balancer itself to the hub and then another set that goes through the hub and holds the A/C pulley on the backside of the hub.
ATI will have to count grooves/measure the balancer in certain ways to help determine the possible part number.
Old Jun 5, 2024 | 08:45 AM
Markolc1981
At first glance, it looks like that balancer does indeed look like a Corvette balancer, but it has 8 ribs which is usually designed for Supercharged applications.
Reaching out to ATI to help identify the main hub is your best bet.
To ATI Balancer for ls1, ls2, ls3
