C5 Fuel Filter
Old Jun 24, 2024 | 03:50 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default C5 Fuel Filter
Has anyone here changed their fuel filter, or considered it as a preventative measure? I currently have my '03 Corvette with 29k miles at the dealer, and I thought it might be a good idea to have the fuel filter replaced as a precaution. It seems like an inexpensive part to swap out for some added peace of mind.
Old Jun 24, 2024 | 04:30 PM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
I'm thinking the same for my recently acquired Z. Probably has never been changed, and although only 10k miles, it may need servicing.
Others should chime in with more knowledge than me.
Old Jun 24, 2024 | 05:48 PM
G_Loc's Avatar
G_Loc
Later 03s through 04 required dropping the tanks to replace the filter no? If yours has it on the frame rail, might as well replace it. It's cheap and easy enough to get to.
Old Jun 24, 2024 | 09:19 PM
hyperv6's Avatar
hyperv6
I changed mine just due time. It is an 02 so it was not hard to get to. Just have to work your arm up in there and use a release tool on the one side.
Note the one on my 02 also is the pressure regulator too.
When cars sit they can clog filters.
Old Jun 25, 2024 | 05:37 AM
Trickskier's Avatar
Trickskier
I would definitely have the dealer change the fuel filter. I have an '03 and the fuel filter was located on the frame. I decided to change mine due to time. It took me about 15 minutes.
Old Jun 25, 2024 | 07:33 AM
JCMDoug's Avatar
JCMDoug
I did mine as part of (while I am in area stuff) during a diff change from 2.73 gears to 3.15. I also did the shift cable at the same time.
Old Jun 25, 2024 | 07:52 AM
02trvette's Avatar
02trvette
Was just looking at mine yesterday and deciding to do it. Not to hijack but I have an 02 A4. Noticed it was pretty tight to get my hand up in there. Can you drop the one exhaust hanger to make it a little easier to get to? Seems all the videos I watched, guys had the M6 and a bit more room to work. Any little tips would be appreciated. Thanks
Old Jun 25, 2024 | 08:05 AM
Missileboy's Avatar
Missileboy
I did mine while I was getting the SC added. Since they were doing the fuel booster and new injectors to support the new fueling, I figured it would be silly not to since it also is a pressure regulator in addition to a filter. Mine is a 02 and had 57K miles on it when I did the swap. Easy job too!
Old Jun 26, 2024 | 07:52 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Well, picked up my car from the dealer today, and lucky me, me '03 fuel filter is in the tank. #FuelFilter4Life !
Old Jun 27, 2024 | 08:35 AM
captain vette's Avatar
captain vette
if your fuel pump is also in the tank you might not be lucky
Old Jun 28, 2024 | 03:16 PM
Yeah, with the fuel filter in the tank, it is a much more work intensive job to change the filter.
To C5 Fuel Filter
