2003 C5 Window leaks
Old Jul 28, 2024 | 11:24 AM
Hugh1969's Avatar
Hugh1969
3rd Gear
Default 2003 C5 Window leaks
I am having a really difficult time getting my driver's side window to stop leaking. I have tried tipping the window in using the adjustment, I have tried to change the position of the stops on the regulator, and I have tried moving the glass itself. Nothing seems to work. It is leaking at the curved part of the glass, and it is leaking at the very bottom of the header seal on the door. Iam in the weeds, so any help would be very appreciated.
Old Jul 28, 2024 | 12:03 PM
jcgunn's Avatar
jcgunn
You are on the right track. There are three adjustments: Up/Down, Fore/Aft and Tip in/out. It takes a while to get it right.
Old Jul 28, 2024 | 12:42 PM
sonicss33's Avatar
sonicss33
Keep trying as you are on the right path. Very miniscule adjustments will make the difference. Just finding the right combination is a bit tricky. You’ll get it.
Old Jul 30, 2024 | 08:57 AM
If you want, I have a number of Word files that discuss water and air leaks on the C5. PM me an e-mail address to send them to and I’ll get them out to you. They may have some tips that will help.
To 2003 C5 Window leaks
