Adjusting a 2000 Convertible window tilt
Old Oct 31, 2024 | 09:33 AM
woodsdesign's Avatar
woodsdesign
Default Adjusting a 2000 Convertible window tilt
Guys, I will be helping a friend adjust the tilt ( in/out) on the side windows as they are now leaking. It looks pretty straight forward but I wanted to reach out to the forum for and tips.
One question is the removal of the door reflector. It looks like simply lifting up slightly and pulling out and down. Is that correct?
The rubber plug on the bottom looks pretty simple.
Simply loosen the jam nut and turn the adjuster counter clockwise to move it in as far as I can see.
Any other tips or insights are appreciated.
Old Nov 1, 2024 | 09:53 AM
woodsdesign
Hasn't anyone adjusted their windows? Is there more to this then I thought?
Old Nov 1, 2024 | 10:11 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
It sounds like you've done your homework. It's pretty easy to do. Only thing I can think of off hand is the reflector might be pretty brittle. Be careful when pulling it out as the tabs that hold it on the top may break off. I've replaced both mine as that's what happened to them.
Old Nov 2, 2024 | 11:33 PM
This file might help.
File Type: doc
Old Nov 3, 2024 | 03:13 AM
sirdano's Avatar
sirdano
When I did mine I pulled door panel off and would let it hang. Because the hard stops for the up also had to be adjusted on mine.
Old Nov 3, 2024 | 06:48 AM
woodsdesign
Thanks for the information, Guys. That is what I was looking for.
To Adjusting a 2000 Convertible window tilt
