[Z06] 900hp?
Old Dec 12, 2024 | 05:03 AM
Teagan Hughes's Avatar
Teagan Hughes
3rd Gear
Default 900hp?
How would I push 900WHP Out of an LS6? And can the Block even handle that?
Old Dec 12, 2024 | 08:30 AM
redzg's Avatar
redzg
It’s been done, though pretty sure not N.A. Will Handzel’s book “How to Build Chevy LS1/LS6 V-8s” is a great read and details a couple of builds that get into that power range.
Old Dec 12, 2024 | 11:58 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
900 wheel is about where I'd stop on factory blocks. Can and have they gone further: yes.
Supercharger or Turbo are the two ways to go.
I've seen it achieved at the absolute bleeding edge of a H/C combo with an overspun V3Ti on E85. "something Dolphin" was the member who had done so just two or three years ago. I think he tipped 998rw. Though I would think a YSi would be preferred.
Turbos can do it as well.
Are you planning pistons and rods here? I would.
Old Dec 12, 2024 | 03:43 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
You will also need a well built transmission.
Old Dec 12, 2024 | 05:20 PM
hyperv6's Avatar
hyperv6
You can but it would not live long.
You might use the block but an aftermarket racing block would live longer.
it would need supercharged Twin Turbo.
I would use an GM 6.0 LSX block and go from there as it will take 1000 hp reliably and a bit more with lower risk.
The LSX is the heavy duty version of the LS and has much more internal strength.
And yes all internals and heads would need upgrades.
To use a stock block or any stock internals it’s likely a hand grenade and a matter of time. The pressures in the cylinders are great and even with all new internals the block will let go.
‘The LS is a strong engine but it is not enough for that much power and live.
Old Dec 12, 2024 | 05:28 PM
Tusc's Avatar
Tusc
4L60E's motto: "It's called trash CAN, not trash CANNOT."
LOL
Old Dec 13, 2024 | 12:16 AM
Teagan Hughes
3rd Gear
100% pistons and rods, should I go forged or Billet with my internals?
Old Dec 13, 2024 | 06:12 AM
hyperv6's Avatar
hyperv6
Forged.
You will need new everything if you plan 900 HP. Even the cooling will need an upgrade.
I would recommend if you are asking questions like this to find a story on a 1000 HP LSX and just look at what all they did. Just Google and a number of videos will pop up. Or find where you can just buy the LSX for $34,000
https://proformanceunlimited.com/sho...-crate-engine/
Read up and see what is needed.
Old Dec 20, 2024 | 02:12 PM
95wht6spd's Avatar
95wht6spd
Look on the FI C5 section, plenty of info and knowledge.
To 900hp?
