Has anyone ELSE beat column lock?
Old Aug 9, 2004 | 02:12 PM
Tom Steele's Avatar
Tom Steele
Default Has anyone ELSE beat column lock?
I finally got column lock about 2 months ago. I have a 2002 Z06 and thought I might be beyond that. But apparently not.
I was parked at my wife's place of work, got in the car. Turned it on and got the message. Turn of the engine, take out the keys and step away from the car... or whatever it says.
I turned off the car, waited (probably less than 10 seconds) and tried again. No luck.
I saw red.
Infuriated, I decided I was driving the car home. Period.
So, I wrenched the steering wheel violently back and forth in an effort to break the locking pin in the steering wheel.
I wasn't able to, but when I went to restart, the column lock released.
I have had this happen once since, and the same method (calculated this time, instead of rage issues) released the steering wheel.
It has not recurred in over a month.
Might I have loosened the pin receiver slot enough to have made it easier for the pin to disengage now?
I'll let you know if the situation worsens.
Old Aug 9, 2004 | 02:38 PM
CAPN17's Avatar
CAPN17
Ever hear of the CLB, if not your will hear from a flatbed one of these times. No one beats one of the Generals booby traps for long, then the General has the last laugh.
CAPN17's Avatar
CAPN17
Old Aug 9, 2004 | 03:06 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
It WILL happen again... its only a matter of when.
Old Aug 9, 2004 | 03:09 PM
NoelsTorchredZ's Avatar
NoelsTorchredZ
My 97 did that just once, then again, then again, and again, and again, you get the point. I was usually able to break it free relatively quickly and worry free until it finaly took me like two hours to break it loose once. Ordered CLB next day, never broke a sweat again
Old Aug 9, 2004 | 06:37 PM
Tom Steele's Avatar
Tom Steele
Default I was afraid of that...
I figured I wasn't the ONLY one to ever lose my temper and break the thing loose.
One other thing I do, is try my very best NOT to set column lock if possible.
Maybe I can trade the thing before it becomes a problem.
Old Aug 9, 2004 | 06:53 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Be sure to post when it locks up on ya next time, far from home....
There are two camps here, people that prevent the issue from happening and those waiting for it to lock on them.
Old Aug 9, 2004 | 08:22 PM
I've had my '00 for better than 3 1/2 years and never had a column lock problem. Just installed the CLB to ensure that it stays that way.
Old Aug 9, 2004 | 08:25 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
https://www.corvetteforum.com/techti...=105&TopicID=1
Old Aug 9, 2004 | 08:38 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
Several here have freed the lock with the violent swing method you mentioned. It is certainly not a fix. I tried this, resetting fuses to no avail. Next day I went back to the car and the lock released correctly. Get the bypass and fix the problem permanently.
Old Aug 9, 2004 | 08:43 PM
Airwilf's Avatar
Airwilf
Getting the column lock recall done this week, putting in the CLB 2 minutes later
Old Aug 9, 2004 | 08:45 PM
SmoknLT4's Avatar
SmoknLT4
Old Aug 9, 2004 | 08:48 PM
Evil-Twin's Avatar
Evil-Twin
By violently manipulating the steering wheel you have started the process of pin misalignment... IF you dont put in the No brainer CL bypass you will sooner or later be stranded.. you just got a warning with the first column lock failure.,... you just put another nail in the column lock problem.. by forcing the pin... sure you got released but you are now deeper in schit...
Old Aug 9, 2004 | 09:39 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
Old Aug 9, 2004 | 10:15 PM
rtpilot's Avatar
rtpilot
Default Clb
Did mine tonight. Only took 20 minutes. Never worry again
Old Aug 10, 2004 | 12:07 AM
jrose7004's Avatar
jrose7004
Mine had never locked before but I was on my way to the dealer for the recall, made a stop and it locked!
Old Aug 10, 2004 | 12:19 AM
gillettij's Avatar
gillettij
I just picked up mycar in
PA on Sat night. Drove it home to FL. I'm assuming it has not been done because the column locks. So that's what I was told. I plan on doing it before it does me, but where's the best place to buy one and how much is is it to have one installed by a mechanic?
Thanks.
p.s. save the wave
To Has anyone ELSE beat column lock?
Old Aug 10, 2004 | 12:25 AM
gordonb50's Avatar
gordonb50
After reading all the posts here, I wasn't going to let it happen to me the 1st time. Ordered & installed the CLB a few weeks ago. Why take the chance when the fix is inexpensive and it takes very little time to install (35 minutes start to finish)? Just buy one and install it. Just my .02 .....
Old Aug 10, 2004 | 12:49 AM
CRWDDYZ's Avatar
CRWDDYZ
Like motorcycle riders...those who have crashed and those that will crash.....CLB
Old Aug 10, 2004 | 12:51 AM
C5 Dawg's Avatar
C5 Dawg
I'm relatively new to the C5s. Is there a cutoff year or date for the steering lock problems? Thanks.
