Has anyone ELSE beat column lock?
Old Aug 10, 2004 | 09:51 AM
Hiteck's Avatar
Hiteck
Originally Posted by CAPN17
Ever hear of the CLB, if not your will hear from a flatbed one of these times. No one beats one of the Generals booby traps for long, then the General has the last laugh.
HaHaHaHa. Well said.
Old Aug 10, 2004 | 10:00 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Originally Posted by C5 Dawg
I'm relatively new to the C5s. Is there a cutoff year or date for the steering lock problems? Thanks.
If you have a 97 to an 04 C5 you have the potential,
Old Dec 12, 2004 | 12:33 AM
Tom Steele's Avatar
Tom Steele
Originally Posted by Mean Green
Be sure to post when it locks up on ya next time, far from home....
There are two camps here, people that prevent the issue from happening and those waiting for it to lock on them.
Just an FYI, I've been meaning to do this for a while now...
NO COLUMN LOCK ISSUES UP TO NOW.
Sorry for all the folks that predicted Doom and Gloom - but so far, my "lose your temper" method has worked.
I still try to avoid setting the column lock (which is hard, since I tend to catch the steering wheel as my fat butt gets in the car) but basically, it hasn't happened since I posted here 4 months ago.
Old Dec 12, 2004 | 07:24 AM
Patman's Avatar
Patman
Originally Posted by Tom Steele
One other thing I do, is try my very best NOT to set column lock if possible.
What do you mean by this? How could you control that? When you shut the engine off you'll always hear the column lock itself, you have no control over that.
Old Dec 12, 2004 | 08:14 AM
Tom/99's Avatar
Tom/99
My son in laws 98 conv, has never had any problems with the column lock.
Old Dec 12, 2004 | 08:24 AM
My advice would be to invest the $60 or so and get the column lock bypass. Its an easy install and it will prevent this from happening. Next time, you may not get it unlocked.
Old Dec 12, 2004 | 08:45 AM
SemperFidelis's Avatar
SemperFidelis
Navigator
okay, if someone does not mind, break this down barney style.
If you just bought a 98, and did not know to ask about clb, and the guy you bought it from does not know, is there a way to find out if there is CLB installed or not? Other, than waiting for this to happen to you....
Old Dec 12, 2004 | 08:50 AM
TkitPlz's Avatar
TkitPlz
I've seen various posts on this column lock issue. What exactly happens and what is the cause? I have an 04 manual 6 speed. Is it more or less likely to happen to me? Thanks. Dan
Old Dec 12, 2004 | 09:00 AM
Darrell G's Avatar
Darrell G
Here is what a forum member told me to do:
With Key off
Turn wheel hard left then
Hard right, keep holding hard right while
Turning on key, then release wheel.
It worked first time. Saved me from having it towed to the dealer. I had it fixed by the dealer. I asked the mechanic about the bypass. He showed me the parts GM uses and explained that it could not malfunction again because the new plate does not have holes for the pin to drop into.
I called GM's 800 cust. relations office and after sending documentation of the repair, they refunded 100%. About one month ago I received an official recall notice from GM. I have a 2000 A4. I think GM intends to recall them all on a year by year schedule.
Old Dec 12, 2004 | 09:40 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
ALL stock '97 to '04 6 speeds and '97 to '00 automatics are potential steering column lock candidates. 2001 and newer automatics do not have a steering column lock.
Old Dec 12, 2004 | 09:55 AM
skyman51's Avatar
skyman51
Does the installation of the CLB create other potential problems? I have read posts that after installing the CLB the DIC started throwing malfunction codes. If that happens doesn't the possibility of the computer still shutting off the fuel exist? How does the CLB prevent that?
Old Dec 12, 2004 | 11:35 PM
Tom Steele's Avatar
Tom Steele
Nah, it only locks if you move the steering wheel into position for it to lock.
Hit it with your leg and you'll hear it click as it locks. I believe there is a ratchet-like mechanism to the column lock and unless you set the steering wheel against that ratchet, it doesn't lock.
Old Dec 13, 2004 | 12:16 AM
  #33
TTopJohn's Avatar
TTopJohn
Instead of a CLB (which a few people claim will screw things up with the BCM over time - don't know if that's true or not), can't you just remove the column lock itself? i.e. install the parts from a 2001+ automatic car into your column lock afflicted car?
This would be preferrable to the recall, which as I understand it doesn't remove the column lock, it just programs the computer to cut fuel to the engine when the column lock locks.
Old Dec 13, 2004 | 12:36 AM
  #34
leaftye's Avatar
leaftye
No codes here. I believe the problem is the column doesn't unlock when it gets the code, but it still thinks it unlocked. The CLB makes the column think it's locking and unlocking like normal.
It is possible to mod the column lock plate, but it's a lot easier to drop the knee pad and plug in the CLB.
SemperFidelis, it's easist to look. If you want, I can post a pic tomorrow of my install.
Old Dec 13, 2004 | 10:08 AM
  #35
plaster's Avatar
plaster
Yes, please post a pic. I need to check mine also!!
Old Dec 13, 2004 | 10:47 AM
  #36
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Funny to still see so many posts on the CL. I remember one guy laughing at so many people because he knew that his would never lock. He thought the reason for the lock was because most people pull on the steering wheel when the get in and out of the car, but then one day PRESTO his CL would not Unlock.
He did admit to it on the forum and then got the CLB. If you have a MN6 your chances of CL is much greater than the A4. I am not sure if I would use one on a car before 00 because of some issues, but 00 and on I definately would use it.
I put my on my 01 MN6 and have no problems or worries.
Old Dec 14, 2004 | 06:59 PM
  #37
plaster's Avatar
plaster
Why not on pre- 00? I have a 99 M6, so I am interested. Also, how can you tell if it has already been done (just bought it)?
To Has anyone ELSE beat column lock?
Old Dec 15, 2004 | 02:01 PM
  #38
leaftye's Avatar
leaftye
Never got around to taking a pic, but this guide can easily help you figure out how to find out if you have it already, and if not, how to install it.
http://www.ls1howto.com/index.php?article=24
Old Dec 15, 2004 | 05:04 PM
  #39
BiggieBoy's Avatar
BiggieBoy
Don't get mad at your car---get mad at yourself. You've been a member for 5 years, undoubtly have read countless threads on column lock problems and you have not yet installed a CLB.....
Old Dec 15, 2004 | 05:56 PM
  #40
goldenboy9r's Avatar
goldenboy9r
i got the recall done 3 days ago and now when I turn the key over it buzzez right before it starts??? what the heck is that?
