Intake and Header Questions
First off, do you see a noticeable gain with an aftermarket intake or is it best to keep the OEM airbox? Before I posted this, I browsed these forums and other pages looking for a definitive answer but had no luck. I have seen a lot of positives about the Vararam and Callaway Honker intakes, but the install is a little more involved than I am capable of doing at this time. The K&N install looks a little bit easier. I've also seen people mentioning the flip-tie mod, but have not looked into the install process for that. I do have plans to supercharge the car in the next couple of years, which would render an aftermarket intake useless. I plan on getting a dyno-tune after these mods are installed, so if people are seeing noticeable gains with an intake versus without I would definitely install one now and sell it second-hand later when I go F/I.
Next question is regarding headers. I am between Kooks and ARH currently. Any noticeable differences between these two brands? I see if I go with Kooks, I would need their X-Pipe whereas the ARH would work with the Corsa X-Pipe. Any longtube headers I buy will be catless.
Lastly, what kind of power have you seen with an intake (or not) paired with a full exhaust? Dyno sheets are a bonus.
Thank you all in advance!
I have Kooks headers on my 2003 running through Corsa sports and they certainly add something but I cannot give you a definitive number. My 2003 runs so much strong than my 2002 that had Corsa extremes but I suspect the PO might have done a little internal work to help. I have Stainless Works long tubes on my 95 and they were good for a seat of the pants gain. I think almost any brand long tubes will give you a nice gain and will be there if you decide to add a supercharger.
Also if you can find a used intake manifold from a 2001-2004 that will help it breathe more than spending money on an intake.
Now what will make a difference is a 3:90 or 4:10 gear. That’s the first change I’d make if my car was stock. If money is a factor then buy a gear swap and some speed engineering headers vs Kooks etc. Do they fit as well? No. Do they fit and work well? Yes
Another thought is just do a mild cam. If you can do the swap yourself it’s cheap if not it’s weigh the cost vs the extremely expensive headers that will not give you the same gain.
https://www.corvetteforum.com/forums...post1595889870
with an intake, headers, full exhaust including z06 catback, I dyno'd at 330 hp and tq.. see the "before" line in the dyno below -- I don't have my stock dyno printout anymore, but iirc, it was around 310.
I've since gone with a super charger and cam and other goodies, that's the other line. but 330ish, maybe a bit more, is what you should expect to see depending on where your baseline is.
Also, why catless? you really don't lose any power from high flow cats these days -- other than the expense, there's really no reason not to include them.
BTW, I do agree with the other comment on gearing .. I have 4.10 gears in mine + 6spd, and love it.
a bigger TB. Hotrod had a article a few years back and MSD and Fast with
a good set of headers and TB were picking up 50 plus hp. The intake was getting
35 hp. Check it out.
Old-school, yeah, cats were a big restriction. But these days, they really have extremely marginal impact.
I have a Vararam, but its collecting dust in my storage unit because with the kit I have I'm guessing a older model as they do seem to improve it over the years is that it would take a lot of time to seal it properly and the way the filter sits just isn't great and was worried I might get some extra crap in there which I don't want. IF I WERE TO DO IT AGAIN. I would still do the intake. Probably Honker. If you are going to supercharge I would just do the zip tie mod until then or push past your fear of not thinking you can install it because you can. Next I would upgrade the clutch/flywheel. I bought my 01 z06 with 21k miles so I'm sure my clutch is fine, but its just not the same feeling like previous cars. If you do headers, 1st gear will become annoying just from the sound when you are trying to be stealthy. Regearing would be another option that is probably cheaper. Seats would be the other thing I wish I did sooner. Don't buy a hand held tuner either. Especially Diablo. Throttle body is another one I think you would have a better feel from as well. Anything that brings in more air will make you go faster, just don't forget about a better fuel pump,pump harness, and injectors to match. I think if you can re gear it, intake and a x pipe with a Z06 exhaust with the throttle body, LS6 manifold, tune you will be happy with it until the supercharger. Skip the headers for now is my advice unless you coat them and protect everything around them and live in a area where you can actually enjoy it and not worry about too much Red and Blue attention. Good luck.
High flow cats were a 15rwhp loss on my full bolt on HCI setup. They were the ones LG sells and good quality. That’s a lot of HP IMO.
I have a great tune and you can’t smell any gas etc at idle.
I still maintain a gear will make the most noticeable difference if your only doing mild bolt on’s. If someone isn’t doing a cam swap a Breathless air bridge and intake, Honker or Vararam are the three with the best design.
some Speed engineering long tubes and x pipe along with a gear and tune.
The FRC already has the 3:42 gear so 3:90 or 4.10. It’s expensive at $2200-2600. SE headers and x pipe are $600 for both and intake $500-700.
I don’t know what shop labor cost for a Cam. Going off memory a friend told me 12 hours. The cam and good lifters are about $1000. My guess a shop would be $2500 or so for parts and labor on that.
I have about $1500 into a set of CNC heads and another $300 in studs
$300 in a LS 2 Silver blade TB not ported plus a Fast 92 intake and Breathless Racing CF air bridge and CAI. I also have a Corsa Sport car back no cars. 453whp 401 tq Cam is a BTR stage 3. That cam will clear stock heads.
used some milled 5.3 heads so I did fly cut my pistons.
I did all the work so I can’t do anything other than speculate on labor. Some shops are reasonable and others are down right criminal.
The heads and cam may not be an ideal project for someone but the others aren’t hard for a person who is mechanically inclined.
Even before I supercharged, with headers, z06cat back, varraam intake, a tune AND hi flow cats, I was at 330hp. highly doubt deleting the hi flows would have put me at 345, but even so, I'd rather just have a cleaner car, and not have to worry about inspections.
I'm not sure what your use is, but if this is an "offroad" vehicle (i.e., track), and your track doesn't require cats, then knock yourself out. But if it's a street car, what's the point? It's a minimal amount of loss, even if your 15 hp number is accurate, and with cats in, the c5 is actually a very clean vehicle. I have cats in mine and I'm at 530 hp :-)
Not sure what you mean by this, just because you can't smell gas doesn't mean it's not polluting.
I looked and can’t find the dyno sheets. I’m not sure if I had ever saved them . You can believe me or not. It wasn’t something I did with posting in mind, but they did lose power. If they hadn’t I would have them on the car now vs sitting on my shelf. I spent the money so obviously there is a reason I took them back off.
What I meant concerning my tune is that I don’t smell any gas like you do in most cars without cats. Generally after a drive in a car without them you stink of gas due to a rich idle. You may have mistakenly thought I cared about the emissions aspect. No inspections in my state.
NA 15hp is a not a small amount. If you think about it people will spend hundreds if not thousands chasing 10-20hp here and there.
This is my second C5, both M6 equipped. I installed 3.90’s in the first, 4.10’s in my current 2004. Gears really wake these cars up in a big way. But, if you are planning on a supercharger then you won’t need lower gears.
After the gears, I installed 243 heads and a midrange cam (218/226, .587/.587, 114+3). Translation: Slight lope, runs smooth like stock-ish under normal driving. Comes on strong a 2500 and charges hard to 5200+ (I simply don’t push it beyond this). Combined with the 4.10 gears it hauls the mail. I went with a power band for occasional, ok, frequent, mini rips on the street, not for track high end. My advice is be mindful of your intended use and spend wisely.
Long and short of it is you can have a screamer without a supercharger or headers or ported heads. That said, all the aforementioned are OUR FRIENDS and definitely add power! It just comes down to how many sets of rear tires you want to buy, lol.
Just don’t bother with the air filter marketing hype. Also, there’s plenty of satisfied Speed Engineering header owners on this forum, so they are worth serious consideration at less than half the cost of Kooks, etc.
Good hunting!
