Sister needs help in Des Moines
Old May 11, 2025 | 08:10 PM
Doug28450's Avatar
Doug28450
Default Sister needs help in Des Moines
My sister has an '04 vert. It appears that over the winter the battery died. Died as in it won't even take a charge, let alone take one long enough to get the car started so she can get it somewhere to get the battery replaced.
Is someone available in the Des Moines area who can help her out?
Old May 11, 2025 | 08:32 PM
leighann1's Avatar
leighann1
1st Gear
Said sister chiming in...Promise I'm a nice person. :-) And my brother is even nicer for trying to help me all weekend.
Last edited by leighann1; May 11, 2025 at 08:35 PM. Reason: Addition to body not enough to add another reply to post.
Old May 11, 2025 | 09:05 PM
BigBS's Avatar
BigBS
Check this video. Works for any dead battery.
Old May 11, 2025 | 09:42 PM
leighann1's Avatar
leighann1
1st Gear
Originally Posted by BigBS
Check this video. Works for any dead battery. https://www.youtube.com/watch?v=Slqd73ZOQvI
Thanks, BigBS but you're dealing with someone who knows nothing about cars. I have no idea what an AGM battery is and to really give you an idea of my knowledge, I got frustrated when I was told to not put the negative clamp on the battery but to put it on a piece of metal on the car. Yeah...this video went way over my head. But thank you!!
Old May 11, 2025 | 10:38 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Changing the battery in a C5 Corvette is SUPER easy.
Literally a 10 minute job even for a newby. You only need 2 tools.
It's ALL in this video. Leighann, you can EASILY do this yourself.
Old May 12, 2025 | 08:35 AM
redzg's Avatar
redzg
I’m much too far away from Iowa, much less Des Moines, but I have had to deal with a dead flat battery while on a road trip.
First suggestion is AAA. If you call AAA they can and will sell and install a new battery right where you are. Fairly certain you have to be a member, but it has proven worth while to me several times over the years.
Second suggestion is a jump stater, lithium or otherwise. Once started drive to an AutoZone who will also sell and install a new battery.
Third suggestion would be to call your local WallyWorld and see if they will install a new battery at the tire/oil change center. Still need a jump starter to get there. I’ve used the Type S with good results:
Amazon Amazon
Old May 12, 2025 | 01:19 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Corvette Club of Iowa is likely to have a member in Des Moines https://www.corvetteclubofiowa.com/
Old May 12, 2025 | 07:22 PM
Do you happen to have a mobile repair shop local to you that can come to your house and change out the battery?
Old May 16, 2025 | 07:38 AM
Joe Scafide's Avatar
Joe Scafide
Join aaa for only $50 a year and they will put a new battery in the car aa is good for all your cars
Old May 16, 2025 | 07:54 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It's been 5 days since the original post. I hope that by now, the OP's sister was able to find the necessary help....
Old May 18, 2025 | 04:59 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I still learned something new. I had already known that you can recover an AGM battery by charging it in parallel with a known good battery. The detail I picked up from this was to preferably not use a trickle charger and to use one with the desulfation mode preferably and which can deliver a 10amp feed. Good details to know since I'll be bringing one back from the dead soon.
Old May 18, 2025 | 08:22 AM
hyperv6's Avatar
hyperv6
ignorance is often why people have trouble with Optima agm batteries. They need different help and many good batteries get trashed.
As for the need here you at some point need to get your hands a little dirty or call a flat bed.
Even my wife could change a battery.
Old May 18, 2025 | 09:01 AM
Tusc's Avatar
Tusc
Not mine.
"A light came on the dash. I can't trust this car anymore. We have to sell it!"
Old May 18, 2025 | 10:47 AM
leighann1's Avatar
leighann1
1st Gear
Thanks, leadfoot4. I was able to get it started with a portable charger. I currently have an appointment with one of the local Chevy dealers for battery replacement and oil change. The third one I called. I left a message for one at 8:20 Thursday morning. Haven't heard a peep out of him. The second one I spoke to at noon on Thursday. He wasn't able to tell me if they had a battery in stock and would call me back. I'm still waiting. The third one I called was crazy helpful, said he only lets his more experienced techs work on Corvettes and called me back within the hour to let me know they didn't have the battery in stock but would have it in time for my appointment this Friday. Pray for sunny skies in Des Moines on Friday!
Old May 18, 2025 | 10:54 AM
leighann1's Avatar
leighann1
1st Gear
It's not that I don't want to get my hands dirty...I just have no clue what I'm doing and I have zero confidence. My battery looks nothing like the battery in the earlier video. It connects on the top and the things that are bolted on are pieces of metal at a 90 degree angle. If I had someone to guide me at each step, I would have no problem trying to do it myself.
Old May 18, 2025 | 10:55 AM
leighann1's Avatar
leighann1
1st Gear
Old May 18, 2025 | 10:58 AM
leighann1's Avatar
leighann1
1st Gear
Old May 18, 2025 | 12:39 PM
leadfoot4's Avatar
leadfoot4
Ignorance is often why people have trouble with Optima agm batteries. They need different help and many good batteries get trashed. i
I agree, and that's why I invested in an Optima charger, a number of years ago....
To Sister needs help in Des Moines
