C5 seat replacemet?
Old May 26, 2025 | 08:29 PM
DSSKing's Avatar
DSSKing
Default C5 seat replacemet?
What's the latest choice for C5 seat replacement? Something like a Corbeau but reasonably priced.
Old May 27, 2025 | 12:10 AM
jdmvette's Avatar
jdmvette
Night Owl for life
C7/thread
Old May 27, 2025 | 12:43 AM
find a really nice set of C7 seats and enjoy the ride.
Old May 27, 2025 | 09:28 AM
AtkRWC's Avatar
AtkRWC
I did the C7 swap and could not be more happy.
Old May 27, 2025 | 01:03 PM
schaumi's Avatar
schaumi
If you don’t think Corbeaus are reasonably priced, please never price out actual racing seats.
Old May 27, 2025 | 06:15 PM
JMG2's Avatar
JMG2
Moderator
c7 seats.
Old May 27, 2025 | 06:32 PM
Dads2kconvertible's Avatar
Dads2kconvertible
C7 seat FS thread OP was asking $2500, which makes the Corbeaus look scandalously cheap by comparison.
Old May 27, 2025 | 06:51 PM
jdmvette's Avatar
jdmvette
Night Owl for life
^ 2500 is a bargain compared to these...free shipping though!
https://www.ebay.com/itm/22677911922...3Avlp_homepage
Old May 27, 2025 | 08:36 PM
DSSKing's Avatar
DSSKing
Thanks. Now the search begins!
Old May 29, 2025 | 06:30 PM
ersatz928's Avatar
ersatz928
Corbeau A4s
Old Jun 6, 2025 | 12:51 AM
RicardC5's Avatar
RicardC5
C7's seats are plug'nplay or need some setup to fit on C5?
Old Jun 6, 2025 | 03:15 AM
jdmvette's Avatar
jdmvette
Night Owl for life
direct fit. drop in, run 3 wires and you're good for the basics.
Old Jun 6, 2025 | 06:26 AM
T-RAY1978's Avatar
T-RAY1978
Quick question on the c7 seats, i understand that memory isn't available, I assume that is based on the key fob not being able to recognize the seat anymore, or is it that the memory button in the car will no longer work, also what about the easy entry function, I really like when I pull the key the seat backs up for easy exit and easy entry and when I put the key in the ignition it puts itself back where I'm comfortable,,,,thanks
Old Nov 19, 2025 | 04:29 PM
MrSev's Avatar
MrSev
1st Gear
Can I ask for those folks who did the C7 seats; hows the leg room. I have Corbeau A4s in my c5 z06 as well and the issue is I cant sit far enough back to be comfortable, like my knees are at too strict an angle. Im just at 6 ft so its not like im super tall. I have a c7 Z51 and love the seats/room in that; have yall had any issue w leg room using c7 seats in the c5
Old Nov 19, 2025 | 07:44 PM
Ltngdrvr's Avatar
Ltngdrvr
I have PLENTY of legroom in mine, I am over 6ft and don't even have the seats all the way back.
Now, I have a coupe, not a vert or FRC, don't know if they are equal on legroom.
Old Nov 20, 2025 | 10:49 AM
MetalMan2's Avatar
MetalMan2
I briefly had C7 seats in my 2001 Z06 (just a quick test fit). 6' 3", longer in the torso. Leg room didn't seem an issue at all, but head room seemed tight. As mentioned it's a 2001 which has more head room than the later years.
Old Nov 20, 2025 | 01:59 PM
JMG2's Avatar
JMG2
Moderator
seats fit exactly the same as the c5. As long as you either swap the c5 belts out for c6 belts or modify the c7 seats to remove the airbag cover, they will go just as far back as the c5 seats. I'm 6'1", and have zero problem with them. Headroom again, is exactly the same as the c5 seats. They're also far more adjustable, so they can adjust up or down, unlike the c5 seats.
To C5 seat replacemet?
Old Nov 20, 2025 | 02:02 PM
JMG2's Avatar
JMG2
Moderator
huh? later years as in the c6 and c7? sure. But if you mean later years in the c5 generation, they are all identical.
the z06 and the FRC actually had LESS headroom than the coupe or convertible. not much less, but less.
Old Nov 20, 2025 | 02:09 PM
MetalMan2's Avatar
MetalMan2
Later years of the C5Z. Later C5Z (2003-2004 ?) received a different headliner than earlier C5Z with a bump that reduced headroom.
https://www.corvetteforum.com/forums...cs-inside.html
Old Dec 7, 2025 | 01:04 PM
Dave 127's Avatar
Dave 127
I just used Corvette central very happy.
