Shocks for c5z
Old May 31, 2025 | 04:52 PM
Ishvir's Avatar
Ishvir
Default Shocks for c5z
Hey guys, I recently slammed my C5Z on longer bolts, and I knew the ride quality was going to be worse; however, I love the look. The question is, have any of you upgraded to different shocks to improve the ride quality while being lowered on longer bolts? And if so, which shocks did you go with?
TIA!
Old May 31, 2025 | 06:36 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
C6 Z06 shocks, direct bolt on.
Old May 31, 2025 | 06:41 PM
Ishvir's Avatar
Ishvir
any specific year?
Old May 31, 2025 | 06:43 PM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Originally Posted by Ishvir
any specific year?
No, just GM Genuine C6 Z06 shocks from Rock Auto or your local dealer.
Old Jun 1, 2025 | 09:18 AM
Gordy M's Avatar
Gordy M
With a slammed Vette You should look at the Bilstein shock (B6), for even better handling the DRM Bilstein shocks. The C6Z shocks were C5Z shocks valved for a heavier car and will raise the car slightly.
Old Jun 1, 2025 | 10:52 PM
Ishvir's Avatar
Ishvir
Thank you! Just ordered the DRM bilstein shocks.
Old Jun 1, 2025 | 11:07 PM
Congrats and hope you will follow up with a review of how the shocks work out for you.
Old Jun 2, 2025 | 10:33 AM
JHrinsin's Avatar
JHrinsin
Very good choice.
The Bilsteins from DRM start with the B8 models which are 1" shorter (designed to work with a lower ride height) compared to the stock length Bilstein B6 replacement units.
Old Jun 2, 2025 | 11:06 AM
Beast's Avatar
Beast
I agree with the post above, Bilstein B8 are for lowered cars. Mine is stock ride height, I went with the B6.
Old Jun 2, 2025 | 11:15 AM
Missileboy's Avatar
Missileboy
Just don't expect the B8's to be plush. The ride if firm (as it should be) and won't be cushy!
Old Jun 2, 2025 | 06:41 PM
Beast's Avatar
Beast
Bilsteins are rough, C6Z shocks are rough. OEM replacement shocks will probably be rough. You want a cushy ride? Buy a good set of adjustable coilovers and put them on the softest setting. I have Y rated tires on mine. W rated and stock tire sizes or close to it will be softer but probably not noticeable. Good luck with your build.
To Shocks for c5z
